dwco5051
reacted to
racerone's post
in the thread
18ft Boat Launch with RWD Suburban
with
Like
How did we manage BEFORE 4 wheel drive became so common.-----As in what percentage of pick-ups was 4 wheel in 1975??
Apr 25, 2026
dwco5051
reacted to
JimS123's post
in the thread
with
Like
I have been launching with a 2 wheel, rear wheel drive since 1968. I never had a problem. I have people come up to me when I was...
Apr 25, 2026
dwco5051
reacted to
Lpgc's post
in the thread
with
Like
I expect some will say it depends on what the slipway is like, how steep it is, is it wet / slippy / etc..
Apr 25, 2026
M
Mc Tool
replied to the thread
Huh , you guys .........I decided after listening to you re ramps etc , to go photograph a few I use reasonably regularly...
Apr 25, 2026
M
Mc Tool
reacted to
racerone's post
in the thread
with
Like
Apr 25, 2026
R
Apr 25, 2026
Texasmark
reacted to
dingbat's post
in the thread
Too Much Prop Issue?
with
Like
Why does a motor with probably less than a couple hundred hours of run time need a new long block and manifolds? A prop buys you...
Apr 25, 2026
R
83 7.5hp, smoke from cowl
Run with cowling off.---Squirt some extra oil into carburetor.----May help pinpoint a leak.
Apr 25, 2026
J
JasonB
Side note, I did put a new impeller in it before running it. Possible I left something out?
Apr 25, 2026
Merc 250 Verado Fuel increase
Don't know which model VV it is, but can remove to get model number off back tomorrow if needed. Voltage readings at Bats with Bat...
Apr 25, 2026
P
Pmt133
Meanwhile half the roads flood from the bay you need to drive down on a regular basis.... yeah the salt air coast vehicles are some of...
Apr 25, 2026
dingbat
Working in the coating industry, I have a bit of insight on the subject. The corrosion rate of carbon steel in saltwater increases...
Apr 25, 2026
M
MikeSchinlaub
Question on cap removal
Remove the rub rail, make sure nothing inside is an attachment point between cap and floor, get three or four beam frames above to lift...
Apr 25, 2026
T
tphoyt
Trail camera issues fixed, now pics from them ...
Some of the hot spots are private lands but hunting is permitted with the land owners permission. The survey started right after the...
Apr 25, 2026
FLATHEAD
That is a ton of deer in some spots! 😮 Are they allowing hunting in those areas with such a concentration of deer?
Apr 25, 2026
