Lou C
replied to the thread
454 mag mpi chuggles/stalls
If a guy can't operate a carbed boat with an electric auto choke, new carbs, etc, then maybe he should not be in command of a twin...
Sunday at 10:34 AM
A
airshot
reacted to
jimmbo's post
in the thread
18ft Boat Launch with RWD Suburban
with
Like
Come for the Food, stay for the Show...
Sunday at 10:05 AM
A
airshot
reacted to
Mc Tool's post
in the thread
with
Like
Youd love this jimmbo This is the Slip inn, and as you can see its right next to the main access ramp to the Marlborough sounds. The...
Sunday at 10:04 AM
A
airshot
Too Much Prop Issue?
If the block has been cracked, it would make maintenance issues come forward....I would definitely want a transom/ stringer check for...
Sunday at 10:01 AM
W
Willyclay
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
Speaking of pins and spacers . . . I made some adjustments to the 'pins' in order to make the installation easier and repeatable. . ...
Sunday at 9:59 AM
A
airshot
Whether prop was original or not makes no difference. Boats and motors don't just come with a prop. Props are always extra because...
Sunday at 9:59 AM
C
carlos515
Question on cap removal
I mentioned before in my original posting of the Sunray, that I will need to replace the hull, stiffeners? Would making the stringers...
Sunday at 9:57 AM
A
airshot
Exhaust manifold discovery?
Most of us boat owners have had to learn some hard lessons over the years, your not alone !
Sunday at 9:52 AM
C
carlos515
That would work also.
Sunday at 9:49 AM
M
MikeSchinlaub
That would be much easier. I've also used a sawzall. Tape a stir stick to a long blade, and put some adhesive backed dand paper on the...
Sunday at 9:46 AM
I
Ilya83
reacted to
alldodge's post
in the thread
with
Like
It doesn't run, then it does, they it doesn't Bad connection somewhere, and that as you know will be hard to find
Sunday at 9:40 AM
vroom ZOOM
Yeah, I thought about that a lot of times. Unfortunately I need to sell the boat, so for a boat getting listed for a bunch of money...
Sunday at 8:44 AM
C
carlos515
The only reason I need to take the cap off is to get the top of the transom ground for new glass. Perhaps I should get a long neck...
Sunday at 8:38 AM
nola mike
reacted to
Lou C's post
in the thread
with
Like
2 four-barrel carb manifolds 2 Edelbrock 4bbl carbs 2 simple low pressure electric fuel pumps from Michigan Motorz that would be my...
Sunday at 8:25 AM
nola mike
Alpha One Gen 2 Shaft Seal Choice
Yeah not sure what I was thinking of there... Doesn't require that on a gen 1, or some gen 1 input shaft seals, so not sure whether I...
Sunday at 8:19 AM
