C
Chuck4741444
posted the thread
Mounting bracket for j200
in
Johnson & Evinrude Outboards
Im changing motor for a 90 160 to a 96 200. I had to add a 5" life kit for the 25 inch shaft, the pictures im post sh I w the...
Sunday at 12:35 PM
C
Chuck4741444
replied to the thread
Motor
Sunday at 12:26 PM
C
Chuck4741444
Motor
Sunday at 12:24 PM
C
Chuck4741444
Motor
After removing the motor, I have started working on a 5" lift bracks for my new to me motor . I used the 2 bottom holes and plugged the...
Sunday at 12:18 PM
P
Pmt133
Too Much Prop Issue?
a 19' boat with a 23" prop sounds like it is in the ballpark... As others have said, start checking everything. Also... make sure the...
Sunday at 11:35 AM
vroom ZOOM
reacted to
Lou C's post
in the thread
454 mag mpi chuggles/stalls
with
Like
If a guy can't operate a carbed boat with an electric auto choke, new carbs, etc, then maybe he should not be in command of a twin...
Sunday at 11:25 AM
Yegboats
Exhaust manifold discovery?
live and learn,working at a dealership I see a few every spring. Thanks for the update.
Sunday at 10:47 AM
Yegboats
reacted to
TXGlastron's post
in the thread
with
Like
Airshot, I’ll take my lumps as deserved. The winterizing was my fault. I had my boat on the lift, and hadn’t been able to get back to...
Sunday at 10:43 AM
Yegboats
reacted to
TXGlastron's post
in the thread
with
Like
After I posted that picture, I discovered both exhaust manifolds cracked. It was NOT winterized properly and the cracking was a direct...
Sunday at 10:42 AM
Lou C
Sunday at 10:34 AM
A
airshot
reacted to
jimmbo's post
in the thread
18ft Boat Launch with RWD Suburban
with
Like
Come for the Food, stay for the Show...
Sunday at 10:05 AM
A
airshot
reacted to
Mc Tool's post
in the thread
with
Like
Youd love this jimmbo This is the Slip inn, and as you can see its right next to the main access ramp to the Marlborough sounds. The...
Sunday at 10:04 AM
A
airshot
If the block has been cracked, it would make maintenance issues come forward....I would definitely want a transom/ stringer check for...
Sunday at 10:01 AM
W
Willyclay
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
Speaking of pins and spacers . . . I made some adjustments to the 'pins' in order to make the installation easier and repeatable. . ...
Sunday at 9:59 AM
A
airshot
Whether prop was original or not makes no difference. Boats and motors don't just come with a prop. Props are always extra because...
Sunday at 9:59 AM
