G
gmarshall43
posted the thread
1939 Evinrude gas tank
in
Johnson & Evinrude Outboards
Hello Is the gas tank for a 1939 1.8hp Evinrude the same size as the 1938 2.8hp Evinrude handiwin? Just wondering if they are...
Sunday at 6:10 PM
R
replied to the thread
pontoon engine pod replacement
Easy fix with some wedges or shimming.
Sunday at 5:56 PM
S
sbs_59
posted the thread
24v Battery Charging Options
in
Electrical, Electronics, Audio and Trolling Motors
Currently have a 24v trolling motor that uses 2 12v batteries with a plug in on board charger. The boat will be docked in a location...
Sunday at 5:50 PM
J
jlh3rd
I've owned my used pontoon since 2017. I've researched all aspects and items including getting new pontoons. I've never seen any type of...
Sunday at 5:37 PM
Lou C
Oil 4 stroke Mercury 115hp
IIRC when Merc came out with their 25/40 mineral oil they also said that if it wasn't available you could use straight 30 in cooler...
Sunday at 5:27 PM
J
jlh3rd
Exhaust manifold discovery?
fwiw. The 2 years in the brackish upper chesapeake with my new in 2021 Merc 115 has not hurt it. Just changed the impeller and checked...
Sunday at 5:24 PM
2005 Mercruiser 5.0L MPI (bravo 3) suddenly started overheating
Might have found a plastic bag floating around and it wrapped it self around the drive. Check your impeller because if may have been burned
Sunday at 5:20 PM
Merc 250 Verado Fuel increase
Working from 2B529482 manual Don't know where this is and it's never done this, can you advise? Will do Don't have this one, can you...
Sunday at 5:15 PM
1966starcraft18ft
posted the thread
in
Pontoons
hey all. so i replaced the 1988 force `125 hp on my 1998 MonArch sunspa 260 with a 1999 Mercury 125 hp outboard. I noticed with both...
Sunday at 5:14 PM
J
jlh3rd
I bought a new Merc 115hp CT in 2021. 10w-30 Merc/quicksilver synthetic is recommended. I'd not deviate from that especially under...
Sunday at 5:13 PM
O
ostrichegg
posted the thread
in
Mercury MerCruiser Sterndrives & Engines
Hi, I have a 2005 Mercruiser 5.0L MPI (bravo 3) on a 1998 Sea Ray sundancer. Boat has run fine for the most part. Usually runs at 170...
Sunday at 5:12 PM
redneck joe
reacted to
Mc Tool's post
in the thread
Just thought I'd share a nice photo.
with
Like
Yeah but they are not unmanageable and they get you into some premo fishing areas , lot of peeps wont use them so you usually have it...
Sunday at 4:55 PM
M
muc
O.P. says this is a new Mercury 115HP Outboard. I would highly recommend using what the owners manual has in it. Application determines...
Sunday at 4:51 PM
Lou C
I have seen guys who are commercial fishermen out in my harbor with their boats....some are left out all winter, this year it was in the...
Sunday at 4:32 PM
M
Mc Tool
reacted to
tphoyt's post
in the thread
Mounting bracket for j200
with
Like
I’m with Crosbyman. I’d fill the old holes with an epoxy filler and start fresh to help keep any water out of a sloppy hole.
Sunday at 4:31 PM
