Lou C
replied to the thread
Exhaust manifold discovery?
It’s not salt water so much it’s the pain of getting at the drains on V6s & V8s, that’s what would stop me from buying another. You wait...
Sunday at 7:55 PM
Hooked on Fishin
Fuel Sending unit
Thank you sir
Sunday at 7:27 PM
Hooked on Fishin
Fuel Sending unit
Thank you Sir
Sunday at 7:27 PM
S
sbs_59
24v Battery Charging Options
Any idea how long it would take a generator to charge the 24v system as is? The cost of a good generator and fuel is comparable with the...
Sunday at 7:20 PM
A
airshot
Oil 4 stroke Mercury 115hp
Wow......just another reason to stick with my old two stroke, looks and runs like new, two stroke oil is 22 bucks a gallon for...
Sunday at 7:16 PM
A
airshot
reacted to
racerone's post
in the thread
with
Like
Motors are too expensive to skimp on oil.-----Use the factory recommended product.
Sunday at 7:07 PM
1966starcraft18ft
pontoon engine pod replacement
ya, i was hoping someone on here had done somthing similar to what i am trying to do and had a recommendation. i have seem on the...
Sunday at 7:04 PM
A
airshot
I would consider a 24v lifepo4 battery. I have been very impressed with mine. I get twice the run time from mine that I was getting...
Sunday at 7:02 PM
1966starcraft18ft
i also need to apologize, i need to correct. my pontoon has a positive transom angle, not negative. the bottom of the transom angles...
Sunday at 6:59 PM
A
airshot
Go to a Fab shop and have one made, or have yours modified to meet your specs. Finding one already made will be scarce, very scarce.
Sunday at 6:57 PM
A
airshot
reacted to
racerone's post
in the thread
with
Like
Easy fix with some wedges or shimming.
Sunday at 6:54 PM
A
airshot
Having an outboard that self drains helps a lot in salt water. Glad I am not close enough to salt water to have those issues.
Sunday at 6:50 PM
D
DeepCMark58A
2026 NFL/CFB News and Nonsense
That is a chocolate for ya. My wife says no more dogs after the two we have but I had a legendary chocolate, thing is living on a lake...
Sunday at 6:45 PM
1966starcraft18ft
i did go out and measure the engine pod and there is a 7 inch negative angle to my engine pod over a 16". i also used the angle finder...
Sunday at 6:44 PM
O
ostrichegg
2005 Mercruiser 5.0L MPI (bravo 3) suddenly started overheating
Thanks. I should have noted, I thought maybe seaweed or something (or maybe a bag) got my drive. But, I don't see anything on the...
Sunday at 6:34 PM
