reacted to
Scott Danforth's post
in the thread
Too Much Prop Issue?
with
Like
2 year old gas is no longer fuel 23 pitch is too high, but motor has other issues
Monday at 4:28 AM
jimmbo
replied to the thread
Oil 4 stroke Mercury 115hp
One of the Oil Companies, but they refine/blend it to Mercury's Specs and uses an Additive Package that is also Specific to Mercury's...
Monday at 12:09 AM
M
Mc Tool
Mmmmm🤔 I wonder who makes that Mercury quicksilver oil for them .
Monday at 12:01 AM
N
Nordin
Cracked bearing carrier, run or replace?
Yes as racerone says, when installing the carrier you have to turn the crankshaft or the prop shaft sligtly. The revers gear and the...
Sunday at 10:40 PM
natispotatis
posted the thread
Bellows Replacement Mercruiser Alpha One Gen 1
in
Mercury MerCruiser Sterndrives & Engines
I have a leaking shift cable bellows. I’ve seen the videos of doing this job with the out drive attached but I’d like to replace all the...
Sunday at 8:36 PM
A
airshot
24v Battery Charging Options
All depends how low the batteries are drained. When I was running dual group 31 agm batteries, they would take at least 12 hours if they...
Sunday at 8:21 PM
Lou C
Exhaust manifold discovery?
It’s not salt water so much it’s the pain of getting at the drains on V6s & V8s, that’s what would stop me from buying another. You wait...
Sunday at 7:55 PM
Hooked on Fishin
Fuel Sending unit
Thank you sir
Sunday at 7:27 PM
Hooked on Fishin
Fuel Sending unit
Thank you Sir
Sunday at 7:27 PM
S
sbs_59
Any idea how long it would take a generator to charge the 24v system as is? The cost of a good generator and fuel is comparable with the...
Sunday at 7:20 PM
A
airshot
Wow......just another reason to stick with my old two stroke, looks and runs like new, two stroke oil is 22 bucks a gallon for...
Sunday at 7:16 PM
A
airshot
reacted to
racerone's post
in the thread
with
Like
Motors are too expensive to skimp on oil.-----Use the factory recommended product.
Sunday at 7:07 PM
1966starcraft18ft
pontoon engine pod replacement
ya, i was hoping someone on here had done somthing similar to what i am trying to do and had a recommendation. i have seem on the...
Sunday at 7:04 PM
A
airshot
I would consider a 24v lifepo4 battery. I have been very impressed with mine. I get twice the run time from mine that I was getting...
Sunday at 7:02 PM
1966starcraft18ft
i also need to apologize, i need to correct. my pontoon has a positive transom angle, not negative. the bottom of the transom angles...
Sunday at 6:59 PM
