A
airshot
replied to the thread
Oil 4 stroke Mercury 115hp
I will add this.....go to the Eway and get on, leave your car in first gear and go cruise at 70-75 mph all day. Lets see how long your...
Monday at 7:10 PM
A
aidanmurphy
Cracked bearing carrier, run or replace?
Tried again today with the new carrier and got the same issue.... 1/8th inch gap left. Tried turning the shaft while sliding it in. I do...
Monday at 6:59 PM
A
airshot
Painting factory diamond pattern non-skid.
I painted some diamond plate years back, but the paint lifted in some areas. Then tried sand blasting the plate. Looked great and paint...
Monday at 6:57 PM
J
Jade Rose Papa
1983 Johnson 140 Horse J140TLCT No Spark.
I have spark, Checked some connections and cleaned a couple that looked a little suspect, Put a full charge on the battery...
Monday at 6:21 PM
C
Chuck4741444
Mounting bracket for j200
Thanks. Ill file them larger.
Monday at 6:12 PM
Kola16
2005 Mercruiser 5.0L MPI (bravo 3) suddenly started overheating
I am not sure on the transom flush port question. 170F for a normal operating temperature of a raw water cooled engine seems high to me...
Monday at 6:08 PM
W
warddog
removing a pontoon off the trailer on land
any way to remove and repost it as a new post?
Monday at 5:42 PM
P
platinumedge
Starter Not Engaging
So, the craft is working & running well. But it's time for me to sell it. I have the proper documents for the boat and the trailer. My...
Monday at 5:38 PM
rothfm
posted the thread
in
Boat Restoration, Building, and Hull Repair
3 years ago, I used Pettit Topside after masking off the border areas on all my topside Diamond pattern non skid. It came out very well...
Monday at 5:27 PM
M
Mc Tool
😁If your trying to get me to say "thats not comparing apples with apples "...... Im not going to ......so there😆😆
Monday at 5:26 PM
Please read the rules you agreed to. Do not post in threads older than 90 days
Monday at 5:12 PM
R
A car engine may be capable of 280 HP.-----But it does not need near that output to move a car on a level road.----Put that car in...
Monday at 5:07 PM
redneck joe
Hot water heater
Not sure of your math so not challenging it per se but we have a long house and use a recirc pump. How does math work into that?
Monday at 5:04 PM
roscoe
Hot water heater
I had a completely different experience. Specialized adapters ? Just tapped into cold supply, and connected to hot out, and a 120v...
Monday at 5:00 PM
M
Mc Tool
No not at ³/¹⁶ " bigger .....hell I wouldnt even mill them ....you got a round file ?. De-burr the edges and get some heavy duty ( like...
Monday at 4:39 PM
