M
Mc Tool
replied to the thread
Oil 4 stroke Mercury 115hp
I think its more about what the engine is designed to do . An R1 yamaha has 200 hp (@13500rpm) at the wheel and is only 998cc , spec...
Monday at 11:57 PM
jimmbo
My Boat will do 67-68mph at 4800 rpm, I don't like to run it(5.7) for long at that Rpm cause it will shorten it's Lifespan Considerably...
Monday at 11:18 PM
M
Mc Tool
Yeah ok what revs is your boat doing at 75 mph.....all day, and anyhow its not about the revs . If you over rev anything it will blow...
Monday at 11:05 PM
M
Mc Tool
reacted to
airshot's post
in the thread
with
Like
I will add this.....go to the Eway and get on, leave your car in first gear and go cruise at 70-75 mph all day. Lets see how long your...
Monday at 10:43 PM
jimmbo
There is a Spec, FC-W for 4 Stroke Marine Engines, just as the TCW-3 for 2 strokes. However that Spec is a Minimum, the low Bar for Oil...
Monday at 10:37 PM
A
ALLONA
posted the thread
Inspecting a 2007 Mako 284 - what to look for?
in
Boat Topics and Questions (not engine topics)
Tomorrow I am going to be doing an inspection and survey on a 2007 Mako 284 I am about to buy, I think I am getting a great deal, but I...
Monday at 9:48 PM
M
MikeSchinlaub
Painting factory diamond pattern non-skid.
I haven't used this specific product, but the prep principals should be the same. It's hard to tell from the picture, but the areas...
Monday at 8:48 PM
Rranger
reacted to
ddrieck's post
in the thread
o. k. to put electric fuel pump on outboard?
with
Like
Re: o. k. to put electric fuel pump on outboard? I disagree to a point... As stated above, do not install an electric fuel pump in...
Monday at 8:04 PM
B
boscoe99
24v Battery Charging Options
What is the main motor? What does its alternator output? One advantage of lithium is how quickly it can be recharged.
Monday at 7:56 PM
S
saltchuckmatt
1983 Johnson 140 Horse J140TLCT No Spark.
It's a 2 stroke....find another outboard. She's done. Airplanes clime, then they level off and descend...outboards are going up hills...
Monday at 7:44 PM
S
saltchuckmatt
Mounting bracket for j200
I see the 3/16 thing now or I get the math, oval the holes...you will be fine. Top only, right? Should need to though. Everything...
Monday at 7:36 PM
S
saltchuckmatt
I have those brackets on my E-tec 115. I've done two of them. They should bolt right on...was your boat missed drilled? You said 3/8...
Monday at 7:31 PM
P
Pmt133
I'm in the "theres a spec and testing for that specs endorsement for a reason" camp. I've messed around and tested various oils in other...
Monday at 7:28 PM
rothfm
Thanks....gonna see what others put here. Then may take 1 small hatch as a test and use a wheel of some sort (that wont gouge the...
Monday at 7:18 PM
rothfm
reacted to
airshot's post
in the thread
with
Like
I painted some diamond plate years back, but the paint lifted in some areas. Then tried sand blasting the plate. Looked great and paint...
Monday at 7:16 PM
