J
Jeff J
replied to the thread
removing a pontoon off the trailer on land
You should not have any trouble pulling the trailer out if you can float or power the boat off the trailer. Is there a spot that may get...
Tuesday at 7:30 AM
J
Jeff J
Fuel Lines
If you do replace it, make sure you leave some extra so it can be cut off and reattached when the inner liner pushes back and cuts off...
Tuesday at 7:24 AM
N
No more boats
posted the thread
Fuel Lines
in
Yamaha & Suzuki Outboards
2000 yamaha OX 66 2 stroke Have a question Never knew the primer ball hose had a double lining , 50 gallon plactic fuel tank...
Tuesday at 7:21 AM
R
Oil 4 stroke Mercury 115hp
Automotive engines are rarely asked to perform at full throttle / maximum power output for long periods of time.----The outboard is also...
Tuesday at 7:20 AM
9
99yam40
I need some input on a 1991 Yamaha c115tlrp
special test equipment is needed along with the specs in you service manual to compare the readings to
Tuesday at 7:15 AM
redneck joe
Random
Tuesday at 6:51 AM
MNhunter1
1973 Starcraft SuperSport 16ft. restoration questions
Some of my builds have taken several years. Life happens and there are many things more important than rebuilding an old boat. I...
Tuesday at 6:21 AM
K
kbrad
Will a standard multimeter check that or do i need a special one ? Thanks again
Tuesday at 6:20 AM
M
mr 88
Inspecting a 2007 Mako 284 - what to look for?
There's a bunch of Mako sites on Facebook, that would be your best bet in getting any feedback on a particular model .
Tuesday at 6:15 AM
K
kbrad
Yes . I have spark tested and no spark on number one coil to number one plug/cylinder if that is what you are asking . Thanks
Tuesday at 5:51 AM
Lou C
When evaluating oils for marine use, one thing I will notice is this: after running the boat up on plane for a while, slow down, let the...
Tuesday at 4:53 AM
M
Mc Tool
Ha ha, bet it lasts longer than your 1st 5.7 😆😆Eat my shorts 🤣
Tuesday at 1:22 AM
Fun Times
454 mag mpi chuggles/stalls
That flame arrester appears dirty or oily too? Might want to remove it, clean it in say a solvent tank if possible, wash/dry it and...
Tuesday at 1:20 AM
jimmbo
A 1 litre 4 stroke spinning 13,500 won't hold together many hrs.
Tuesday at 12:53 AM
Fun Times
Mercruiser 5.7L and 5.0L, help me identify a part
The engine serial number is challenging to read but I suspect the number to be 1A087486 which is close enough to locate your engine...
Tuesday at 12:45 AM
