Fun Times
replied to the thread
Coil wire install
https://www.ebay.com/itm/404968941657#:~:text=This%2520Quicksilver%2520Marine%2520Insulating%2520Compound%2520seals%252C%2520waterproofs%...
Tuesday at 9:47 AM
S
SeaRayboater95
Coil wire install
Mercruiser #18 Service Manual. I usually use Dielectric grease as well. When I removed this wire from the coil, it was glued in there...
Tuesday at 9:42 AM
flashback
Coil wire install
what "book" It's been my experience that it needs to be clean. the dielectric grease would be fine.
Tuesday at 9:34 AM
S
SeaRayboater95
Coil wire install
Thanks Mike for your response. The manual calls for "1/2 oz insulating compound". Not sure what that is.
Tuesday at 9:04 AM
nola mike
Coil wire install
I would normally go with Dielectric grease in this case, but not sure what the manual specifies
Tuesday at 8:51 AM
nola mike
Trailer tires.
Every car I've owned had much greater inner wear than outer. Guessing anything reasonably sporty runs with a good amount of negative camber.
Tuesday at 8:47 AM
S
SeaRayboater95
posted the thread
Coil wire install
in
Mercury MerCruiser Sterndrives & Engines
Hey Guys and Gals, quick question. I am working on a 2012 Larsen with a 4.3 Mercruiser. Changing wires and plugs and the coil wire was...
Tuesday at 8:46 AM
nola mike
Hot water heater
Mine was gas
Tuesday at 8:29 AM
8
83bluefin
1983 Blue Fin 16’ Resto
You mean I’m supposed to keep the trailer attached to the boat when I launch? ;) I found a place that will direct print in Carbon Fiber...
Tuesday at 8:29 AM
W
warddog
removing a pontoon off the trailer on land
That is part of the delima.
Tuesday at 8:12 AM
W
warddog
I have a 55HP tractor with a front-end loader (no trailer hotch on that) BUT do have clamp on forks and thought originally that I would...
Tuesday at 8:09 AM
D
DeepCMark58A
Then one has to ask, how are you going to get the pontoon back out?
Tuesday at 8:03 AM
J
Jeff J
I almost buried my truck loading my 17’ aluminum boat bass boat at an unimproved ramp. Water was high and made the ground soft. There...
Tuesday at 7:57 AM
R
Throw a good anchor in the water and winch it off the trailer at the water's edge ???----Any pictures to show what the challenge is ?
Tuesday at 7:50 AM
B
Bman2895
1978 Johnson 140hp running rough. Need advice
So I've been away a bit. But I decided to swap the later 140 carbs on. Smaller bore carbs but from a 82or 83 140. Fixed ALOT of the...
Tuesday at 7:33 AM
