J
Jeff J
replied to the thread
removing a pontoon off the trailer on land
I don’t know how strong the clamp on forks hold for pushing and/or pulling. A ball could be put on the end of a fork if it can handle...
Tuesday at 11:00 AM
L
lgaytan
Nobody fishing?
Nice catch this weekend
Tuesday at 10:55 AM
nola mike
reacted to
Jeff J's post
in the thread
Trailer tires.
with
Like
I was not speaking of the inside versus outside corners. It’s normal for the inside corners to wear first. I was responding to an...
Tuesday at 10:51 AM
nola mike
reacted to
Fun Times's post
in the thread
Coil wire install
with
Like
https://www.ebay.com/itm/404968941657#:~:text=This%2520Quicksilver%2520Marine%2520Insulating%2520Compound%2520seals%252C%2520waterproofs%...
Tuesday at 10:51 AM
J
Jeff J
The pontoons will likely need to be more than half underwater to float in the back. I haven’t messed with one that didn’t have a motor...
Tuesday at 10:50 AM
redneck joe
reacted to
piperjoe's post
in the thread
1973 Starcraft SuperSport 16ft. restoration questions
with
Like
Thank you, my friends, for your understanding. I really believe the reason for my heartfelt posts concerning Joyce is that I am scared...
Tuesday at 10:45 AM
A
airshot
Oil 4 stroke Mercury 115hp
Just look around at all the high performance 4 stroke engines, dragsters, nascar, Indy type...etc...these all run at high rpm, and they...
Tuesday at 10:43 AM
J
Jeff J
Trailer tires.
Tuesday at 10:43 AM
redneck joe
reacted to
MikeSchinlaub's post
in the thread
Boats from work.
with
Like
More truck pics. Some damage to the inner support panels too, as well as the hood seperating from them. Everything is just epoxied...
Tuesday at 10:42 AM
A
airshot
reacted to
racerone's post
in the thread
with
Like
Automotive engines are rarely asked to perform at full throttle / maximum power output for long periods of time.----The outboard is also...
Tuesday at 10:37 AM
M
MikeSchinlaub
Boats from work.
Tuesday at 10:28 AM
S
SeaRayboater95
reacted to
flashback's post
in the thread
Coil wire install
with
Like
what "book" It's been my experience that it needs to be clean. the dielectric grease would be fine.
Tuesday at 10:24 AM
S
SeaRayboater95
reacted to
Fun Times's post
in the thread
Coil wire install
with
Like
Tuesday at 10:22 AM
M
MikeSchinlaub
1983 Blue Fin 16’ Resto
Windshields often dont even have gaskets on the mating surface. You could put a bead of silicone down if you want.
Tuesday at 10:18 AM
jimmbo
1978 Johnson 140hp running rough. Need advice
Smaller Bore? That will cost top end Hp, but will help Hole Shot
Tuesday at 10:07 AM
