  • S
    SunnyD1964 replied to the thread ID needed please..
    There's no stamp i looked, and the title just says traveler boat no model or anything. The reason why i said i believe it to be, is...
  • dingbat
    dingbat replied to the thread MS Office alternative.
    It would have to be very old file format. I'm running Office Pro 2021 on my work lap top. The only files formats I can't open are those...
  • J
    JonBoat55 reacted to Scott06's post in the thread Alpha1Gen2 gear oil leak with Like Like.
    you wouldn't see it in the third pic as I think you are just looking at the front side of the bellhousing. If the lower seal in the...
  • J
    JonBoat55 replied to the thread Alpha1Gen2 gear oil leak.
    Will pull and pressure test tonight. I was just looking to see if it was obvious to anyone what the leak was/wasnt based on the location.
  • tango13
    tango13 replied to the thread Coil wire install.
    Glued or corroded? Mine was stuck in too - poor design on the boat, and the coil sits right under the seam between the hood and the...
  • S
    In terms of Permatex I was thinking silicone. I read someone recommended Permatex No.3 aviation gasket maker (slow drying and non...
  • C
    Not exactly true. Telltales clog all the time, but the volume thru them is very small, so cooling is not affected if just the telltale...
  • T
    Outstanding! I can’t say thank you enough for this knowledge share. You have given me a number of things to do, read about, and consider.
  • MNhunter1
    MNhunter1 replied to the thread New Journey.
    Wiring was a tedious process and I still have some finish work and wire management left to do, but everything works so far! I took a...
  • S
    Thank you for the repair instructions. I have also found heat and a crayon can do wonders.
  • S
    some heat and some "Free-All" will remove that screw
  • S
    To replace the bushing/seal you will need to replace the shift lever because the screw will not come out, you will need to break the...
  • S
    I developed this repair https://www.clubsearay.com/threads/for-mercruiser-only-shift-cable-thread-repair.93826/
  • MNhunter1
    Also got all the "spares" and "projects" tucked away nicely, aside from the extra parts lying around. Need to find a good spot to keep...
  • MNhunter1
    Big milestone yesterday...got the motor mounted! Also got my first mow of the year in, which had me looking at my mess of a garage...
