JonBoat55
Thread starter- Joined
- Aug 26, 2019
- 96
Hey all. Uncovered the boat today and saw the gear oil monitor bottle was empty. Gear oil looks like it slowly leaked out of the weep hole on the lower unit port side. Replaced the shift shaft seal, carrier seal and water pump last fall after finding a small amount of water during the gear oil change. Shift shaft seal was bubbling during the pressure test.
So what did I mess up when putting everything back together before lay up?
Thanks
If it was an upper seal problem, I'd see from the third pic, correct?
Thanks
