Alpha1Gen2 gear oil leak
JonBoat55
Hey all. Uncovered the boat today and saw the gear oil monitor bottle was empty. Gear oil looks like it slowly leaked out of the weep hole on the lower unit port side. Replaced the shift shaft seal, carrier seal and water pump last fall after finding a small amount of water during the gear oil change. Shift shaft seal was bubbling during the pressure test.
So what did I mess up when putting everything back together before lay up?
Thanks
If it was an upper seal problem, I'd see from the third pic, correct?
Scott06
Thanks
you wouldn't see it in the third pic as I think you are just looking at the front side of the bellhousing.
If the lower seal in the upper was leaking you'd see it in the exhaust cavity and on the water pump.
at this point you need to pull the drive and pressure test. When you did the shift shaft seal did you get just the seal or did you get the whole plastic housing with the seal in it? I did just the seal and could never get it to not leak in the plastic housing...
if the whole bottle leaked out willing to bet you will find a bunch of gear oil when you split the two halves. Im not sure if the drain hole you see it coming out of drains the exhaust cavity or the intake side of the water pump. if the water pump intake your shaft seal below the water pump is leaking, if the exhaust likely your driveshaft seal in underside of upper. this is easy to damage when putting the halves together.
JonBoat55
Will pull and pressure test tonight. I was just looking to see if it was obvious to anyone what the leak was/wasnt based on the location.
JonBoat55
I think I may have found the problem.
Used my finger to gently feel first, used the screwdriver for the video. Upper oil seal kit and spanner wrench ordered.
  • IMG_0899.mov
Scott06
if I recall correctly you will need to pull the vertical shaft and gear out and the race for the bearing above the seal to change it. If you dont have it get Mercruiser manual 14 will have all the correct sequnce to do the repair.
You might as well do your input shaft seal while you are in there.
