A
alvinkarlsson69
reacted to
Mc Tool's post
in the thread
Spark on only one cylinder- 1997 Evinrude 50HP BE50TLEUC
with
Like
Lots of multi cyl motorbikes do to. Gotta confess I googled the op's model number ....saw it was carbed and assumed it would be a...
Today at 12:48 AM
A
alvinkarlsson69
replied to the thread
Nothing changed when it switched out the power pack. I still only had spark on one cylinder. What could cause the motor only to spark on...
Today at 12:47 AM
A
alvinkarlsson69
reacted to
Mc Tool's post
in the thread
with
Like
If it helps your diagnosis , I think your motor has a "waisted spark " ignition . One coil with two leads.....the coil fires twice per...
Today at 12:44 AM
M
Mc Tool
Today at 12:35 AM
S
saltchuckmatt
Points more to the power pack when this condition exist. Mc Tool....yamaha's both fire at the same time at least the ones I've worked...
Yesterday at 11:46 PM
Kola16
Quicksilver 44357Q2 Through Gear Case Flushing Kit
Yes it is worth it. $75 though? Ouch! I just stick a welding filler rod through my regular $10 muffs. Drill a little hole in the center...
Yesterday at 11:44 PM
S
saltchuckmatt
1978 Johnson 140hp running rough. Need advice
If what you describe is happening you will soon have a ship anchor if you keep running it.
Yesterday at 11:40 PM
M
Mc Tool
Thank you 🙂 Make sense when I think about it ....as the op says runs on one cylinder ....which is way better than none if you dont like...
Yesterday at 9:14 PM
M
Mc Tool
reacted to
racerone's post
in the thread
with
Like
Orange / blue stripe fires the top cylinder.----Orange / green stripe fires the bottom----Blue is the sky ( top ) , green is the bottom...
Yesterday at 9:13 PM
J
Jmunk
I/O (Sterndrive) Conversion to Outboards
I find it amazing how strong fiberglass and resin can be when combined.
Yesterday at 8:22 PM
A
airshot
Which kicker mount to install?
I would not trust just bolts and nuts as they could pull thru the fiberglass. Some type of backing plate will still be highly recomended !
Yesterday at 8:08 PM
K
KD4UPL
24v Battery Charging Options
How long is a string? If you have 100 Ah batteries making your 24 volts and they're down half way that's 50 Ah to put back. If you have...
Yesterday at 7:49 PM
C
Cdn20valve
posted the thread
in
Non-Repair I/O and Inboards
https://www.amazon.ca/Quicksilver-44357Q2-Through-Gear-Flushing/dp/B000XBOUIY/ref=sr_1_2?sr=8-2 Is this kit worth the higher price then...
Yesterday at 7:29 PM
R
Yesterday at 7:20 PM
C
carlos515
Question on cap removal
Ok thanks, What would a 20ft bow rider cap roughly weigh? Perhaps a few Hangman scaffolds Like Chris1956 suggests would be a better idea.
Yesterday at 7:15 PM
