S
SunnyD1964
posted the thread
1964 Traveler I Think
in
Boat Restoration, Building, and Hull Repair
Is this normal after you sand off the paint? This is my first restoration.any advice is greatly appreciated and welcomed, trying to...
Yesterday at 7:12 PM
M
MikeSchinlaub
replied to the thread
Question on cap removal
Be very careful with just 2. That leaves a lot of room for flex, and the cap isn't very rigid when seperated from the hull.
Yesterday at 7:09 PM
M
MikeSchinlaub
1981 Springbok 18' Restoration/Renovation
Aluminum boats have square sheets of aluminum screwed to the bottom of the floor under the pedestal locations. I would suggest this, as...
Yesterday at 7:08 PM
M
Mc Tool
Spark on only one cylinder- 1997 Evinrude 50HP BE50TLEUC
How does it work then .....roughly 😃 always keen to learn 🙂🙂
Yesterday at 6:59 PM
M
Mc Tool
reacted to
racerone's post
in the thread
with
Like
Wrong assumption.
Yesterday at 6:58 PM
C
carlos515
Unfortunately my trailer is a roller one. My hull is dimpled from the rollers as it is. I have been building a cradle to support the...
Yesterday at 6:51 PM
Ifishmuskie2
I had this problem. I put an extra layer of 1/2” plywood 20” square under each seat. I used toggle nuts to attach the seat bases after...
Yesterday at 6:45 PM
T
TXGlastron
Glastron GXL 235 anti siphon valve location?
I have circled the part I’m wondering about. I have unscrewed without issue the brass fitting. However, the square aluminum looking...
Yesterday at 6:38 PM
roscoe
35hp choke linkage hookup?
Correct. I just checked my 35 hp, and that is where it connects. From what I can tell, this spring just holds the choke open when it is...
Yesterday at 6:37 PM
roscoe
reacted to
Chris1956's post
in the thread
with
Like
The choke linkages were mostly the same on the inline motors of that vintage. I think the stud that holds the plastic grating also...
Yesterday at 6:33 PM
R
Wrong assumption.
Yesterday at 5:50 PM
B
boscoe99
24v Battery Charging Options
115 two stroke or F115 four stroke?
Yesterday at 5:39 PM
S
SlipperyOar
Needing some advice here. My floor will be made from 1/2” plywood that’s going to be sealed and wrapped in marine vinyl. Under the floor...
Yesterday at 5:36 PM
M
Mc Tool
If it helps your diagnosis , I think your motor has a "waisted spark " ignition . One coil with two leads.....the coil fires twice per...
Yesterday at 5:32 PM
S
samrcho
reacted to
redneck joe's post
in the thread
How much is it worth?
with
Like
It is worth what you are willing to pay for it. 20 year old boat is 95% going to have hidden issues especially if it has been moored in...
Yesterday at 5:24 PM
