D
DeepCMark58A
replied to the thread
Very short dock lines
It will be fine until it isn't.
Jun 4, 2026
B
boscoe99
reacted to
99yam40's post
in the thread
2004 Yamaha 150hp oil sensor light
with
Like
I wonder if being tilted up allowed the oil pump pick up to suck air. also does anyone know if the oil pressure sensor is a switch or...
Jun 4, 2026
C
ChooChooSnakeMan
Best "low effort" towable?
Glad you found something that works and the fact you got a good deal on it don't hurt! Be safe and enjoy the boating season. I'm...
Jun 4, 2026
R
ricodudink
Water or oil in Cylinders
When I rebuilt the engine, I didn’t spend any time on the exterior, and I haven’t replaced the starter or the alternator yet. However...
Jun 4, 2026
nola mike
4.3 Ignition swap
But should be able to use either
Jun 4, 2026
Ayuh,...... What, exactly, did you do to "rebuild" this motor,..?? I ask, because it don't look like a rebuilt motor in yer...
Jun 4, 2026
C
ChooChooSnakeMan
Bimini Top Hold Down Bracket is loose, need fix
Scott, Well I'm not too excited about your reply but I do appreciate it and respect your experience with boats. I'm a engineer and...
Jun 4, 2026
C
ChooChooSnakeMan
I've thought of that but the area is very cramped to begin with, the side wall of the fiberglass vertical panel is very close and to...
Jun 4, 2026
Scott06
intake and exhaust on your engine are the same manifold. So could crack into the intake just same same as exhaust, unless the intake...
Jun 4, 2026
M
Mc Tool
reacted to
redneck joe's post
in the thread
Random
with
Like
Jun 4, 2026
R
ricodudink
I removed the manifold after your message and noticed that all the exhaust ports are completely dry. What surprised me is that all the...
Jun 4, 2026
guy48065
posted the thread
in
Boat Topics and Questions (not engine topics)
I need to tie my pontoon as close to the end of my dock as possible because it's pretty shallow--esp. right now thanks to no rain. I've...
Jun 4, 2026
Scott06
that is fine for a pressure test. no issue Yes it is possible the exhaust is cracked. Normally folks do a test filling the manifold...
Jun 4, 2026
T
tphoyt
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
It's going . . . :LOL: The bottom seam is all filled in and glassed, and the entire pod is sanded in preparation for fairing compound...
Jun 4, 2026
S
stevh1155
reacted to
racerone's post
in the thread
Replacing water pump impeller for first time
with
Like
Run carburetors dry before letting boat sit for a week or more.-----If there is a separate oil injection unit ( autoblend ) throw it in...
Jun 4, 2026
