reacted to
MikeSchinlaub's post
in the thread
Boats from work.
with
Like
Sealer. Painted. Reducing the photo size did some wonky things to the walls.
Jun 4, 2026
M
MikeSchinlaub
replied to the thread
Boats from work.
Jun 4, 2026
aspeck
daily music fix
Just came across the Gothard Sisters Trio ...
Jun 4, 2026
M
MikeSchinlaub
Bimini Top Hold Down Bracket is loose, need fix
It could also be studs in T nuts in the back of the cushion. I very much agree. Cutting a 3 inch access hole behind the cushion won't...
Jun 4, 2026
R
ricodudink
Water or oil in Cylinders
The head yes, the block I am not sure…
Jun 4, 2026
Ayuh,..... I assume they pressure tested the head, 'n block,..??
Jun 4, 2026
H
Holden1
posted the thread
1995 60hp Power Tilt Trim Conversion
in
Johnson & Evinrude Outboards
I have a 1995 60HP Johnson (J60ELEOC) with manual tilt. Is it possible/what would be needed to convert it to power tilt/trim? Could I...
Jun 4, 2026
flashback
Anyone want to live at sea full time?
They're doing fine with their rockets !
Jun 4, 2026
aspeck
reacted to
ratdude747's post
in the thread
Best "low effort" towable?
with
Like
Finally got the tube out today, Worked great, although I'll look to add a booster ball as rope spray was an issue.
Jun 4, 2026
when you do get stuck, dont panic. I had a panic attack and cracked a rib when I got stuck between the bilge gutter and the engine.
Jun 4, 2026
if its held on with clips, there will be one or two locking screws. look in the drain holes (if equipped) or under welting. then slide...
Jun 4, 2026
flashback
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
It's going . . . :LOL: The bottom seam is all filled in and glassed, and the entire pod is sanded in preparation for fairing compound...
Jun 4, 2026
aspeck
Very short dock lines
Shouldn't be a problem ... from your description you shouldn't have enough wave action to do any harm ... as long as there are no large...
Jun 4, 2026
aspeck
reacted to
DeepCMark58A's post
in the thread
with
Like
It will be fine until it isn't.
Jun 4, 2026
B
boscoe99
2004 Yamaha 150hp oil sensor light
If the motor was tilted up when started it is not unreasonable to think the pick up tube will be out of the oil. I am still confused...
Jun 4, 2026
