R
ROY WILLIAMS
reacted to
rogerrabbitis's post
in the thread
1975 Mercruiser Tilt/trim issue
with
Like
ok thanks I will look up that post and from my test I don't belelve I have a collapes line when we crack the line at the pump the...
Jun 4, 2026
R
ROY WILLIAMS
reacted to
in the thread
with
Like
I am going to try to use it this weekend and see how it goes... oping it may clear it's self at this point till I find a new pump
Jun 4, 2026
A
airshot
replied to the thread
Trolling Walleye. Any insight?
Colors seem to change every year and it all depends on where your fishing and what the fish are used to seeing. Over my 40 plus years...
Jun 4, 2026
A
airshot
reacted to
Scott Danforth's post
in the thread
with
Like
Yep .... Catch, Fillet, Release
Jun 4, 2026
A
airshot
reacted to
alldodge's post
in the thread
Robalo2440 1995 Nav light needs repaired
with
Like
Good you found something but I see more than just the glare at night issue. The light is not taller than your Bimini top, so the light...
Jun 4, 2026
A
airshot
Bypass oil injection 2000 90ELPTO
Good to know, my last OMC motor was from 1988 and it did not work reliabily, so mechanic showed me how to bypass it. Motor did not idle...
Jun 4, 2026
A
airshot
Jun 4, 2026
FLATHEAD
reacted to
aspeck's post
in the thread
daily music fix
with
Like
The Gothard Sisters are from the state of Washington and they seem to like to highlight the nature of Washington State in their videos ...
Jun 4, 2026
88 Capri (2022 SOTY)
1989 omc cobra gear case problem
Did you find out what the problem was?
Jun 4, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
An afternoon of fairing compound. . . this is the vinyl ester fairing compound that I got from a supplier in CT. It is good for below...
Jun 4, 2026
P
Pmt133
reacted to
MikeSchinlaub's post
in the thread
Boats from work.
with
Like
Sealer. Painted. Reducing the photo size did some wonky things to the walls.
Jun 4, 2026
aspeck
daily music fix
Jun 4, 2026
I'm seeing a change not in previous rendering. Is the angle piece going to cause some spray after water leaves trim tabs?
Jun 4, 2026
tpenfield
Jun 4, 2026
aspeck
reacted to
in the thread
Boats from work.
with
Like
Jun 4, 2026
