Seasons Recreational
reacted to
tphoyt's post
in the thread
Aluminum transom has had heat distortion
with
Like
Looks like a solid fix. Glad you got it all sorted out and don’t have to always wonder what’s going to happen.
Jun 8, 2026
reacted to
mike_i's post
in the thread
with
Like
well done.
Jun 8, 2026
W
Willyclay
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
It is disconnected for the time being.
Jun 8, 2026
eggs712
reacted to
tpenfield's post
in the thread
with
Like
Having done quite a bit of fiberglassing recently, I tend to go with the longer (wider) piece on the first layer and then progressively...
Jun 8, 2026
W
Wrenchstench92
replied to the thread
71 silverline comoro
Hey guys what’s up. Apologies to revive an old thread, but there is a method to my madness. Just joined the forum, found the site from...
Jun 8, 2026
eggs712
reacted to
Seasons Recreational's post
in the thread
with
Like
Still need to paint the back end, but was able to slip the coosa under the new enforcement.
Jun 8, 2026
J
joep1980
reacted to
Sea Hawk's post
in the thread
trim tabs, how big is too big?
with
Like
Re: trim tabs, how big is too big? Tabman,<br /> I rechecked my transom and found that the 18" tabs would work great. Even the 20"...
Jun 8, 2026
J
jrabbit
2007 evinrude etec 40 hp
Ok I didn’t realize that showed issues. When it is running the injection/ignition light is glowing
Jun 8, 2026
I
ironring1
posted the thread
Honda BF8 tilt lever spring
in
Honda & Tohatsu/Nissan Outboards
I have an older (90s) Honda BF8 as the kicker on my boat. It runs great, but the spring that is supposed to push the tilt lever in when...
Jun 8, 2026
Kwanza
Oil pressure switch / oil pressure sender
An update on diagnosing this above issue. It certainly looks like the mechanical fuel pump. 1. Removed hose from pickup/anti-syphon...
Jun 8, 2026
K
KD4UPL
electricians? Breakers, GFCI, AFCI
You don't get to decide the breakers. The code and inspector dictate that. Some circuits AFCI is required, other circuits require GFCI...
Jun 8, 2026
K
KD4UPL
Early 2000's Rinker
As someone who owned a Bayliner, then a Larson, and now a 2004 Rinker 232 I can tell you the Rinker us WAY better than a Bayliner. I've...
Jun 8, 2026
P
Pmt133
reacted to
MikeSchinlaub's post
in the thread
Boats from work.
with
Like
Someone did this just to hide the rot and trade in.
Jun 8, 2026
C
Crosbyman
being an ETEC look at the side LEDS on the EMM (CPU) when you run the engine. report findings top to bottom leds at KEY ON...
Jun 8, 2026
J
jws123
Mercruiser 454 I Need Help Identifying This Engine
Thanks for the information!! I have one other dumb question that im confused about. This is the engine In the boat its seized and scrap...
Jun 8, 2026
