M
Mc Tool
reacted to
DeepCMark58A's post
in the thread
Killing time
with
Like
Nope no 22 I have a 22 but it is in a closet. My options are 410, 20 gauge, 45 acp or buckshot and brass from the judge. I am going with...
Jun 9, 2026
JonBoat55
reacted to
Bondo's post
in the thread
How to tighten up rack/pinion slack in steering
with
Like
Ayuh,..... Odds are, the rack, or pinion gear, or the cable housing is worn,...... The "Fix", is replacement,....
Jun 9, 2026
B
boscoe99
replied to the thread
Lower unit repair
Different perspectives on the world. I worked for one company the majority of my life and then for five plus years following that with...
Jun 9, 2026
L
Lloyd R
Mercruiser Coil Wiring
Thanks for taking an interest in helping me out! This is with out the cap.
Jun 9, 2026
jimmbo
Mercruiser 888 Unexpected Prop behavior?
There are other Brands of Props. Mercury/Quicksilver, Turning Point, Solas to name a few.
Jun 9, 2026
If it's a resistor block, the thunderbolt ignition has been changed Post a picture of the distributor without the cap A ballast...
Jun 9, 2026
ratdude747
Piranha doesn't make a 20 (at least in 3-bladed 14.5" "A" blades). I thought they did, but it seems they don't.
Jun 9, 2026
1975 Mercruiser Tilt/trim issue
Ayuh,...... Reverse lock is done in the pump on later systems,..... Drive position is done in the pucks, after they were added to...
Jun 9, 2026
reacted to
Scott06's post
in the thread
with
Like
yes. Get a factory manual for your set up you will find it invaluable if drive came up in reverse I would think you have a bad reverse...
Jun 9, 2026
tpenfield
I/O (Sterndrive) Conversion to Outboards
In the cabin . . .
Jun 9, 2026
jimmbo
I would expect about 3800 with the 21, and no change in Load. In the Past, a loose Rule of Thumb was to Prop to hit Max, with the...
Jun 9, 2026
redneck joe
reacted to
DeepCMark58A's post
in the thread
Killing time
with
Like
Jun 9, 2026
redneck joe
^^^note^^^ he said factory.
Jun 9, 2026
reacted to
alldodge's post
in the thread
VP 5.7 TBI bogging down
with
Like
Should be 30 psi with TBI Take the fuel filter off and dump the contents into a clear container to make sure there is nothing but clear...
Jun 9, 2026
jimmbo
Lower unit repair
Every Business, looks for any and all Reasons to deny a Warranty Claim, almost as intensely as Health Insurance Companies go out of...
Jun 9, 2026
