P
Pmt133
replied to the thread
I/O (Sterndrive) Conversion to Outboards
Is it just an optical illusion or does the extension have a slight hook to it? And you don't see that side anyway! Looks good
Thursday at 3:23 PM
flashback
Looks good from here. :) Once it gets wet you'll never see the bits.
Thursday at 3:23 PM
P
Pmt133
reacted to
tpenfield's post
in the thread
with
Like
Gelcoat day . . . My first time spraying gelcoat :unsure: I put a coat of VE primer on a couple of days ago and today did the gelcoat...
Thursday at 3:22 PM
flashback
reacted to
tpenfield's post
in the thread
with
Like
Thursday at 3:21 PM
M
Mc Tool
reacted to
racerone's post
in the thread
Can anyone help me with removing a flywheel?
with
Like
Heat , freezing and potions are not needed.----A proper puller and a hefty hammer to give the pusher bolt a bump.
Thursday at 3:17 PM
M
Mc Tool
reacted to
racerone's post
in the thread
with
Like
If the nut was tightened too much , you end up with the flywheel taper stretched well over the crank taper.----Factory puller and a bump...
Thursday at 3:16 PM
R
Post a picture of the threads on the crankshaft.----Starting to look expensive and time consuming.
Thursday at 3:12 PM
tpenfield
Thursday at 2:59 PM
JustJason
Battery not charging.......
You really need a DVA to check the voltage out of the stator if you are going to DIY this.
Thursday at 2:53 PM
T
tphoyt
reacted to
redneck joe's post
in the thread
cooking
with
Like
and I always say if its good enough for supper its good enough for breakfast. Egg was perfect. Butter, S&P in the butter, crack eggs...
Thursday at 2:52 PM
T
tphoyt
reacted to
redneck joe's post
in the thread
cooking
with
Like
things are settingling on at the new house and i'm starting to look again. Been using a cheap table top grill I got for a tailgate at...
Thursday at 2:52 PM
kbh121956
posted the thread
Chrysler 35hp Tachometer
in
Force & Chrysler Outboards
Hello, Will a Vintage Chrysler Outboard 74H09 Tachometer work on a 1974 35hp battery ignition? on the back is a switch from 1,2.3,4...
Thursday at 2:51 PM
Franco_boater
reacted to
Scott06's post
in the thread
First time bellow job Alpha One Gen2
with
Like
if it makes you feel any better it took me two weekends to get it it done. I had an issue with the bushing in the bellhousing where...
Thursday at 2:39 PM
W
Wrenchstench92
1971 Silverline Comoro 16.5
Yeah that’s what I figured, I read one of the posts of the user friscoboater of his restoration and he mentioned like you said, cut...
Thursday at 2:35 PM
W
Wrenchstench92
reacted to
MikeSchinlaub's post
in the thread
with
Like
3/4 would be fine for stringers, it just gives you a narrow area to hit with the screws. Hard enough to hit a 2x that's really only 1...
Thursday at 2:30 PM
