redneck joe
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
Gelcoat day . . . My first time spraying gelcoat :unsure: I put a coat of VE primer on a couple of days ago and today did the gelcoat...
Thursday at 5:47 PM
redneck joe
replied to the thread
Artificial Intelligence
i bypass the AI results mostly and scroll down to thelinks so I can think for myself
Thursday at 5:46 PM
C
Crosbyman
Can anyone help me with removing a flywheel?
hum... why not grind away the top of the crankshaft to clean the threads down maybe 1/8 inch clean up the threads with the nut or...
Thursday at 5:46 PM
M
MikeSchinlaub
1971 Silverline Comoro 16.5
Sure, no problem. I would leave that open so water can drain along the keel. Make sure to cut drain holes along the keel in the...
Thursday at 5:33 PM
M
MikeSchinlaub
reacted to
alldodge's post
in the thread
Boats from work.
with
Like
nice rig, and nice work
Thursday at 5:31 PM
J
jmcdaniel
reacted to
DC20's post
in the thread
Bravo 3 Speedometer tube
with
Like
Re: Bravo 3 Speedometer tube I am, looking right now to see if I can find a tach that matches the rest of the Faria/Larson gauge set...
Thursday at 5:26 PM
Franco_boater
First time bellow job Alpha One Gen2
Will see I hope..., last question. Please confirm to me after drive installation I have to follow amazing Chris video to find 6inch...
Thursday at 5:25 PM
M
Mc Tool
Battery not charging.......
Plus one for the Chinese reg/rect , just make sure they get adequate cooling 🙂
Thursday at 5:17 PM
P
Pmt133
Water in gear oil... (Not a great day)
Shift shaft seal. Though it holds 20psi for ~20 minutes if you wiggle the shaft it sprays out air
Thursday at 5:09 PM
FLATHEAD
You’re probably your own worst critic. You’ve done a great job on that
Thursday at 5:01 PM
P
Pmt133
Sadly I'm an alpha 1 upper with an MC-1 lower. Similar but not the same.
Thursday at 4:59 PM
FLATHEAD
reacted to
tpenfield's post
in the thread
with
Like
Thursday at 4:56 PM
Scott06
I think that goes from inside to protect the shift cable where it goes through the metal transom housing . I didn’t change mine as I...
Thursday at 4:38 PM
Franco_boater
Keep us posted please! Im looking forward for any reseal job on A1G2
Thursday at 4:33 PM
Franco_boater
reacted to
Pmt133's post
in the thread
with
Like
It's not a ton, but it was all through the drain of the lube so that's enough. Was originally planning on doing the impeller and other...
Thursday at 4:33 PM
