R
replied to the thread
Johnson won't start
The " no oil " in the lower unit seems to explain it all.-----Take lower unit apart for repairs as needed.----Might be cheaper to find a...
Saturday at 10:33 AM
I
iggyw1
Johnson won't start
Yes, I turned the flywheel by hand, and I had a good pisser going when I left the dock. This motor never ran hot for me as yet. Thanks...
Saturday at 10:12 AM
I
iggyw1
Johnson won't start
Racer One, I replied over an hour ago that I will drain the oil, but failed to hit send, so I sent it now. I just drained the oil, and...
Saturday at 10:11 AM
T
TnTommy
Shifting into reverse is really hard
Ok found the problem thanks chris1956 got me going in right direction with cleaning shift rod and looking for parts that are not moving...
I
iggyw1
Johnson won't start
I will drain the gear oil to see if there are shavings in it. I did not change the water impeller since I had the boat two years ago...
Saturday at 10:00 AM
A
airshot
reacted to
dingbat's post
in the thread
West Marine files for Chapter 11 bankruptcy
with
Like
Locally, we used to have one every third intersection. Been dropping like flies for the past 5-10 years. Only know of a couple within a...
Saturday at 9:58 AM
A
airshot
reacted to
jlh3rd's post
in the thread
Left side lean?
with
Like
" I'm not a boat guy" I'm responding based on this. Do you mean "leaning" or "turning". Some outboards have an adjustable trimming tab...
Saturday at 9:56 AM
P
Pmt133
reacted to
Chris1956's post
in the thread
with
Like
I do not think the PCA Premium has the anti-slime ingredient. I also tried Micron which did not work as well.
Saturday at 9:39 AM
T
tphoyt
Johnson won't start
Can you turn the flywheel by hand. I would be suspicious of an over heat.
Saturday at 9:01 AM
Artificial Intelligence
And on August 29th skynet became self-aware
Saturday at 8:57 AM
C
Mercury 850 85hp. Good engine or stay away?
Mark, the 115HP IL6 was indeed an 850 with another carb and two more cylinders, labrinth seal and reed valves. The Mercs were modular...
Saturday at 8:56 AM
C
Saturday at 8:52 AM
nola mike
reacted to
redneck joe's post
in the thread
with
Like
i used to order online from a place called iboats.com....
Saturday at 8:52 AM
FLATHEAD
There is one 40 miles from me. Been there a few times to pick up items that I needed right away. They seemed to be stocked fairly well...
Saturday at 8:50 AM
redneck joe
saw one in the wild in Seattle while on vacation at the folks. Walked around, meh.
Saturday at 8:20 AM
