M
Mc Tool
reacted to
jlh3rd's post
in the thread
GPS Speedo
with
Like
Meant to add... Also when fine tuning my trim at speed, it can show speed difference 1 mph +/-....if someone wanted to be that precise.
Saturday at 3:26 PM
replied to the thread
Trim Pump Bench Bleeding?
Ayuh,..... Put it back in, 'n see if the drive works,....
Saturday at 3:24 PM
470 to 120 swap
Ayuh,...... Should be a plug, 'n play,.....
Saturday at 3:21 PM
Rranger
posted the thread
470 to 120 swap
in
Mercury MerCruiser Sterndrives & Engines
I have a complete 120hp mercruiser setup prop to front engine pulley installed in a boat now. Have a chance for a better boat with a...
Saturday at 2:44 PM
I
iggyw1
Johnson won't start
Thanks again. I do have oars AND I do have on the water towing service available on any lake in Michigan, so I will be ok if...
Saturday at 2:39 PM
P
PaulCT
1989 J225TLCED: retrofit 1996-2001 90 deg looper Al carbs?
Jimmbo: Existing engine is also 225. My concern is exactly along the lines you point out: I'm not sure how the internal plumbing...
Saturday at 2:37 PM
M
MikeSchinlaub
'77 Holiday Transom
The transom isn't glued in, should be lots of bolts. The usual method is to take off the motor, then the cap on the splashwell and pull...
Saturday at 2:20 PM
redneck joe
Artificial Intelligence
that is my little sister birthday. Coincidence??
Saturday at 2:12 PM
R
Johnson won't start
For me the " bump " when it was running is a HUGE clue.----Then again " hope " is eternal.-----Go ahead and run it.-----Make sure you...
Saturday at 2:01 PM
K
kjdunne
posted the thread
Johnson 150 gearcase pressure testing
in
Johnson & Evinrude Outboards
2000 J150, I replaced water pump as regular maintenance and all seals while I had the unit off. The factory manual says to pressure...
Saturday at 12:19 PM
flashback
reacted to
jimmbo's post
in the thread
West Marine files for Chapter 11 bankruptcy
with
Like
Translation: Give us Time to insure we can increase Compensation for all the Useless, and Incompetent Executives, and Management who...
Saturday at 12:07 PM
FLATHEAD
Can anyone help me with removing a flywheel?
So much for brute force. Who knows what other surprises you’ll uncover. I’d be looking for a replacement running motor if I were you.
Saturday at 11:41 AM
N1265
posted the thread
'77 Holiday Transom
in
Boat Restoration, Building, and Hull Repair
Hi guys, I am pulling my OB motor off my 1977 18' Holiday to replace the board that goes in between the motor and the outside of the...
Saturday at 11:27 AM
I
iggyw1
Johnson won't start
Problem I have with this motor is that I cannot identify if it is a 30 or 35 H.P. 1990 Johnson. There are no numbers, tags, serial...
Saturday at 11:06 AM
W
Willyclay
reacted to
iggyw1's post
in the thread
Johnson won't start
with
Like
Racer One, I replied over an hour ago that I will drain the oil, but failed to hit send, so I sent it now. I just drained the oil, and...
Saturday at 11:02 AM
