S
saltchuckmatt
replied to the thread
Johnson won't start
Might want to pull the starter apart and service it as well. Clean, ohm out and brush kit. 6 out 10 on the knowledge level.
Yesterday at 10:24 PM
Toyelectroman
posted the thread
F115 stalls at low rpm
in
Yamaha & Suzuki Outboards
Hi, I have been having an intermediate problem on my 2017 F115 where it will stall at idle or in gear in a no wake speed. Doesn't happen...
Yesterday at 9:56 PM
BWR1953
GPS Speedo
I have a Faria Platinum GPS Speedo. Works great. I tested it by connecting a small 12v battery to it, put on my truck dash and drove...
Yesterday at 9:50 PM
BWR1953
reacted to
Mc Tool's post
in the thread
GPS Speedo
with
Like
Pitot tube speedos are marginally better than a drunken wild stab in the dark as far as accuracy and consistency is concerned, whereas...
Yesterday at 9:47 PM
W
Wrenchstench92
1971 Silverline Comoro 16.5
Good evening, I appreciate the tips Scott. I will keep them in mind. I was able to get the boat backed into the garage today, this way I...
Yesterday at 9:15 PM
L
lintmann
Trim Pump Bench Bleeding?
Well Bondo that is great advice and is actually what I ended up doing this morning. I did remove the shuttle valve last night just to be...
Yesterday at 8:31 PM
ratdude747
GPS Speedo
I GPS'd my gauges when I redid them as part of a larger overhaul (pitot tube setup was destroyed and useless). But while I mostly used...
Yesterday at 7:59 PM
M
MikeSchinlaub
1998 Sylvan 1700 Blue, now Gold Fish exterior freshen up
Not bad, gold is a difficult color to spray, but why does the white stripe look wobbly? Personally, I think some blue would go well with...
Yesterday at 7:55 PM
M
MikeSchinlaub
reacted to
Bugzilla46310's post
in the thread
with
Like
Bought from the original owner last fall. Fairly good condition but with some dock rash. Repainted the exterior and new decals going to...
Yesterday at 7:52 PM
J
jws123
Mercruiser 454 I Need Help Identifying This Engine
The drive is already removed does anyone know a good place to get short blocks? The engine i was going to use after honing the cylinders...
Yesterday at 7:48 PM
A
airshot
reacted to
Mc Tool's post
in the thread
GPS Speedo
with
Like
Yesterday at 7:40 PM
B
boscoe99
GPS Speedo
Depends upon what speed is desired. Speed through the water (think boat and motor performance) or speed between two points in space...
Yesterday at 7:37 PM
I need a recommendation for steering in an old LUND boat
Get a u-flex or seastar. Most of the companies from the 70s-90s no longer exist
Yesterday at 6:53 PM
Bugzilla46310
reacted to
rk970's post
in the thread
1965 Pacific Mariner 16'
with
Like
Repowered last year and painted the transom/splash well..
Yesterday at 6:44 PM
C
Crosbyman
Johnson 150 gearcase pressure testing
if it isn'T sealing ypou will see soon enough...go 10 minutes and see what happens ...
Yesterday at 6:42 PM
