C
replied to the thread
1989 J225TLCED: retrofit 1996-2001 90 deg looper Al carbs?
The service manual is very careful to explain how to install the bowl and other screws into the plastic carb bodies, so they do not...
Today at 4:20 AM
Bugzilla46310
1998 Sylvan 1700 Blue, now Gold Fish exterior freshen up
White stripes are a very unique starburst style. You get this effect when you use plain old masking tape and the eurathane paint bleeds...
Today at 4:16 AM
C
Johnson 150 gearcase pressure testing
Gee, what seals did you replace? Unlike Merc's driveshaft seals, Johnnyrude gearcase seals have nothing to do with the waterpump.
Today at 4:14 AM
C
carlos515
GPS Speedo
Thank you all for the advice.....The Newport GPS speedo is discontinued for my boat. I looked at the connections of my gauges and they...
Today at 3:47 AM
reacted to
Scott Danforth's post
in the thread
I need a recommendation for steering in an old LUND boat
with
Like
Get a u-flex or seastar. Most of the companies from the 70s-90s no longer exist
Today at 3:43 AM
B
Berkley1
VP 5.7 TBI bogging down
Wanted to Thank everyone for their input I found that the issues was a loose hose from the MAPP sensor to the throttle body once taken...
Today at 3:34 AM
jimmbo
What is this part?
It is a Trim Limit Switch. The Early style of Power Trim, the one you have, used it to limit how far the Motor could be Trimmed out. The...
Today at 3:32 AM
reacted to
lintmann's post
in the thread
Trim Pump Bench Bleeding?
with
Like
Well Bondo that is great advice and is actually what I ended up doing this morning. I did remove the shuttle valve last night just to be...
Today at 3:15 AM
reacted to
Rranger's post
in the thread
470 to 120 swap
with
Like
Thank you matt167. Been awhile since I seen u on here Bondo I have great respect for your opinions. Thank you.
Today at 3:12 AM
M
Mc Tool
Just thought I'd share a nice photo.
🙂No it blimmin didnt , I almost didnt post it but then I dont usually mess with the camera (phone) settings so it might not all be the...
Today at 3:05 AM
redneck joe
cameras never do it justice do they.
Today at 2:00 AM
redneck joe
reacted to
Mc Tool's post
in the thread
with
Like
8am
Today at 1:05 AM
M
Mc Tool
reacted to
kjdunne's post
in the thread
with
Like
2000 J150, I replaced water pump as regular maintenance and all seals while I had the unit off. The factory manual says to pressure...
Today at 12:45 AM
R
Ronniewhite
2000 25hp Johnson 3 cylinder
It was the coil wire coming off the coil. It's good too go again
Yesterday at 11:36 PM
S
saltchuckmatt
reacted to
Crosbyman's post
in the thread
with
Like
if it isn'T sealing ypou will see soon enough...go 10 minutes and see what happens ...
Yesterday at 10:25 PM
