redneck joe
reacted to
Pmt133's post
in the thread
Just thought I'd share a nice photo.
with
Like
Its like this one. I see this photo and feel the energy and atmosphere of it but it really doesn't do what it looked like any justice.
Today at 6:39 AM
redneck joe
replied to the thread
cooking
so tired of my Meater bluetooth probe. Too inconsistent in performance, battery usuage hih, not rechargeable, etc> Anyone us one they...
Today at 6:39 AM
R
Johnson 150 gearcase pressure testing
If seals are 25 years old, it was good practice to replace them.
Today at 6:37 AM
K
kjdunne
Thanks Crosbyman. Chris, sorry for not not being more specific. I replaced all gearbox seals, driveshaft seals under the water pump...
Today at 6:35 AM
GPS Speedo
Most gauges no longer have studs
Today at 6:28 AM
I
iggyw1
Johnson won't start
Thanks to all of you. I am planning on taking it out on the lake today. I am going to run it then come home, then after a few hours...
Today at 6:22 AM
Mercruiser 454 I Need Help Identifying This Engine
You can't just dingleberry hone cylinders. You need to bore the block, then hone it. Not sure where you are at, but there should be a...
Today at 6:19 AM
P
Pmt133
Today at 6:14 AM
Lou C
VP 5.7 TBI bogging down
Solutions help others!
Today at 6:04 AM
Lou C
reacted to
Berkley1's post
in the thread
with
Like
Wanted to Thank everyone for their input I found that the issues was a loose hose from the MAPP sensor to the throttle body once taken...
Today at 6:04 AM
Scott06
Try michigan motorz they do reman engines not sure if they offer short blocks but they have long blocks
Today at 5:45 AM
dingbat
reacted to
Chris1956's post
in the thread
1989 J225TLCED: retrofit 1996-2001 90 deg looper Al carbs?
with
Like
The service manual is very careful to explain how to install the bowl and other screws into the plastic carb bodies, so they do not...
Today at 5:08 AM
redneck joe
no you did fine. There is just no way to capture the whole thing and the feeling you get standing under/in/thru/over/all of it.
Today at 5:00 AM
redneck joe
Random
https://www.facebook.com/share/r/1CiUXJ5gWQ/
Today at 4:59 AM
C
What is this part?
Yes, that is the trim limit switch. A lot of them are broken by this point and need to be bypassed to use the SPDT PTT switch on the...
Today at 4:25 AM
