acadian2022
replied to the thread
1982 200hp high-performance "Franken-motor" hybrid build serial number 6033659 block casting has the J92W stamp
Hi thank you very much for your help. as for the diagram you provided and my pictures I dont see anything missing on my engine then...
Jul 19, 2026
C
captainnate
New Journey
very nice work
Jul 19, 2026
R
1981 Johnson 90 HP overheating, but not all the time
They guide water through the water jackets.----And nothing to do with the speed of the water. ---Make sure to install head gaskets...
Jul 19, 2026
BWR1953
Really dry around here
But to be fair, I was in a classified situation don't ya know. 😝
Jul 19, 2026
C
captainnate
1972 Starcraft Nova
I finally got the floor vinyl glued and stapled in. I also redid the side inside storage pocket on the port side. I did this side...
Jul 19, 2026
A
affa
Exhaust bellow slipped off
I didnt use adhesive on the bellhousing side, and I guess its there it`s off
Jul 19, 2026
metalchewy
Picked up a 1990 Force 50HP yesterday.
Engine ran well last night. It started every time with just a twist if the key. No cranking to make it run, no fouling. Was an...
Jul 19, 2026
JustJason
They serve 2 purposes. First is they force water around the cylinder walls to allow for even cooling of the cylinder walls (IE 1/2 of...
Jul 19, 2026
Dukedog
"reason I'm asking after finding TDC moving the flywheel literally pulling the flywheel off and moving one hole over".. don't know what...
Jul 19, 2026
bajaman123
Water pump rebuild after 11 years and 600 hours
Yours is definitely the winner as far as hours go! I've had friends and family that got close to 500 hours out of the pump on an Alpha...
Jul 19, 2026
bajaman123
reacted to
DeepCMark58A's post
in the thread
with
Like
Well that old impeller didn't owe you anything.
Jul 19, 2026
Berdink
reacted to
ranger335's post
in the thread
with
Like
Yes, 180 something and 165.
Jul 19, 2026
Berdink
reacted to
ranger335's post
in the thread
with
Like
I have welder fingers, so I'm not a good judge.
Jul 19, 2026
bajaman123
DP Drives - Strike Protection?
Yes, the outdrive will kick up but generally only when the skeg is hit and whilst in forward motion. Be aware there are a number of...
Jul 19, 2026
ranger335
Can you explain what the diverters do? I don't have a problem with replacing them, I just want to understand.
Jul 19, 2026
