redneck joe
reacted to
captainnate's post
in the thread
1972 Starcraft Nova
with
Like
I finally got the floor vinyl glued and stapled in. I also redid the side inside storage pocket on the port side. I did this side...
Jul 19, 2026
I
icatchfish
posted the thread
1972 evinrude 50hp 2 stroke. Crank no start.
in
Johnson & Evinrude Outboards
Howdy, As the title says. Story: Motor hits a wall on revs under load. Did up both carbs with new needles, floats, and gaskets. Cleaned...
Jul 19, 2026
A
airshot
replied to the thread
Water pump rebuild after 11 years and 600 hours
Not judging at all....you got lucky. You might stop and pickup a few lottery tickets and see if your on a roll ! I certainly would.....
Jul 19, 2026
A
airshot
Solar chargi g
How close is the nearest power outlet to where you store your boat ? Solar can work but it will get $$$ real quick.
Jul 19, 2026
A
airshot
Old timers formula question
You might consider an epoxy coating as the Spar being trapped under wet carpet will not last long. Epoxy will last far longer....
Jul 19, 2026
A
airshot
Constant drain of 1 of 2 batteries
If drawing down overnight you have a healthy draw or the battery may have an internal short. Disconnect the battery and see how long it...
Jul 19, 2026
I
icatchfish
Bed liner for fiberglass hull
Took much longer to find time to get the boat on the water. It floats! Or at least it doesn't sink fast enough to cause panic lol...
Jul 19, 2026
D
DeepCMark58A
reacted to
dingbat's post
in the thread
Grandkids on the dock
with
Like
Enjoy them while you can. They grow up quick. My eldest daughter lives 6 hours away. Between the distance and my travel schedule at...
Jul 19, 2026
B
boatsboatsboats
Thanks. May as well take the extra step now, hopefully this floor will last 20 years.
Jul 19, 2026
B
boatsboatsboats
reacted to
roscoe's post
in the thread
with
Like
the spar is an extra layer of protection you can probably skip it, but that carpet is going to hold water for a long time. the spar...
Jul 19, 2026
metalchewy
posted the thread
Force 2 cylinder throttle cable adustments
in
Force & Chrysler Outboards
Trying to figure out throttle cable adjustments on a 1990 Force 50. When put in forward gear, it engages the drive, but can move the...
Jul 19, 2026
dp-c shafts and gears still available?
No, not new but you can get rebuilt drives for a fair amount of money There used to be a conversion transom shield kit about 25-30...
Jul 19, 2026
B
brunolund
to add another question then, if parts are non-existent, or might as well be, what is the preferred option for a new drive? is there...
Jul 19, 2026
Lou C
I bet you're not in salt water. Because if the last guy who did it (either at the factory or dealership) didn't coat the threads of the...
Jul 19, 2026
R
DP Drives - Strike Protection?
Best protection is a GPS plotter.----So cheap these days compared to lower unit damage and downtime.
Jul 19, 2026
