R
replied to the thread
F70 boggin
A 16' boat with a 70 should fly.-----Have the motor performance checked on a dynamometer.
Jul 19, 2026
Watermann
Transom Reinforcement
I have a 115 Merc 4 cyl on my 18' SS and it weights in around 400 lbs. Although the V5 variant does have double knee braces with a very...
Jul 19, 2026
DP Drives - Strike Protection?
Did a rock strike with a DP290a. Back in 2012. Lost 2 blades (one off each prop) folded 3 more over. And the drive kicked up. Came in...
Jul 19, 2026
metalchewy
Force 2 cylinder throttle cable adustments
Thank You @Nordin . I didn't adjust the throttle connector at all. It's as it was when we took the outboard and linkage off the donor...
Jul 19, 2026
Fun Times
reacted to
Scott06's post
in the thread
Exhaust bellow slipped off
with
Like
I had the oem clamp walking off the exhaust bellows on the bellhousing side of my gen 2 when I did it a couple years back. I think the...
Jul 19, 2026
Scott06
Jul 19, 2026
Fun Times
Hopefully without too much of a thread highjack scenario here, by chance Muc, Jmunk and any others, do you all know of any floating...
Jul 19, 2026
F
findinghomer
1997 5.7L thunderbolt ignition. Slow crank
Okay I'm going to get an engine ordered this week, think I'd rather just order a reman rather than have mine rebuilt just think it'll...
Jul 19, 2026
F
findinghomer
reacted to
alldodge's post
in the thread
with
Like
Heads are the same so far as exhaust matting surface. You get more HP with vortec
Jul 19, 2026
M
Mc Tool
F70 boggin
That aint such a heavy boat ...,😬 are you using the correct procedure trim /throttle wise wise , just how "grown " are these 3 adults...
Jul 19, 2026
D
DeepCMark58A
Bed liner for fiberglass hull
Still doesn't take much to do.
Jul 19, 2026
metalchewy
reacted to
Nordin's post
in the thread
with
Like
The connector for the throttle is spring loaded (#3). The purpose of this is that the gear shifter will engage the gear fully before the...
Jul 19, 2026
D
DeepCMark58A
anyone ever try this?
I could see in salt water, not sure freshwater.
Jul 19, 2026
aspeck
Nope, not me ... interesting ....
Jul 19, 2026
Lou C
Water pump rebuild after 11 years and 600 hours
can't go wrong following the FSM!
Jul 19, 2026
