R
rbwhiz
replied to the thread
1996 Penta 5.0Fi and SX COBRA
Thank you. I'll be checking that this week.
Jul 20, 2026
R
rbwhiz
Not exactly sure how. But I'm wondering about this. Because it took like 30 seconds to build up to 32 lbs..... Was def not immediate...
Jul 20, 2026
R
rbwhiz
reacted to
alldodge's post
in the thread
with
Like
Welcome Don't see it as a drive issue Is this a new to you boat? I'll assume you don't have a scanner, so I would start with the...
Jul 20, 2026
R
rbwhiz
reacted to
Lou C's post
in the thread
with
Like
running in the water is different because of the under water exhaust back pressure, wonder if you have either restrictions (anti siphon...
Jul 20, 2026
flyingscott
Water pump rebuild after 11 years and 600 hours
What does the pee stream mean?
Jul 20, 2026
flyingscott
reacted to
Mc Tool's post
in the thread
Does this Belong to a 1994 V4?
with
Like
That is part of a fuse One leg of the fuse with the fuse bit fizzed off . Not exactly the same coz I wasnt going to scroll thru all...
Jul 20, 2026
F
findinghomer
1997 5.7L thunderbolt ignition. Slow crank
Also. I have a 2BBL carb, will this manifold bolt onto a vortec? And will I have to run a different fuel pump or will the mechanical...
Jul 20, 2026
Berdink
Sputtering Johnson V4 90hp - 1994
How about the recirculation valves? I guess I can check that they aren't plugged, or stuck open.
Jul 20, 2026
Berdink
What's the bleed system? Bowls aren't plastic.
Jul 20, 2026
flashback
reacted to
dingbat's post
in the thread
Artificial Intelligence
with
Like
How better to train machine learning modules than to have direct interaction/exchanges with potential "content" providers?
Jul 20, 2026
flashback
reacted to
tphoyt's post
in the thread
with
Like
It’s learning how to take over
Jul 20, 2026
FLATHEAD
reacted to
aspeck's post
in the thread
Trail camera issues fixed, now pics....
with
Like
Jul 20, 2026
reacted to
tphoyt's post
in the thread
with
Like
Jul 20, 2026
R
Check the bleed system.-----Inspect float bowls for warpage if plastic. ----Just run this motor.
Jul 20, 2026
Dukedog
1982 200hp high-performance "Franken-motor" hybrid build serial number 6033659 block casting has the J92W stamp
look in this general area for a "date stamp" on tha block.. its there but may be hard ta make out..... may be behind tha timin' arm but...
Jul 20, 2026
