D
DeepCMark58A
replied to the thread
Got my flow meter working today
I also just ordered a filter to remove the stuff that clogs the sprinkler screens.
Jul 20, 2026
stripped SX-A (3L VP) dipstick threads
3/8-16 Thread-sert
Jul 20, 2026
redneck joe
daily music fix
the year i was born https://www.facebook.com/share/v/1H1YzCm3pc/
Jul 20, 2026
reacted to
dingbat's post
in the thread
Constant drain of 1 of 2 batteries
with
Like
Sounds crazy, but switch your bilge pump selector from auto to off or pull the 5A in-line fuse(s) that feed the bilge pump(s) at the...
Jul 20, 2026
reacted to
Gerkin's post
in the thread
Engine won't shut off
with
Like
Thank you for all your replies. Very helpful. Fixed the issue. You we right. The alternator should not have gone to the key...
Jul 20, 2026
1997 5.7L thunderbolt ignition. Slow crank
The 2BBL isn't an issue but the manifold is, the Mans have different bolt patterns Assuming you have a mechanical fuel pump so you...
Jul 20, 2026
Berdink
Sputtering Johnson V4 90hp - 1994
Moving on to the bleed system (recirculating system and valves). Looks like I get to take the carburetors off again. 😊
Jul 20, 2026
Berdink
@racerone, I saw you post in another thread about a way to check if the crankcase isn't sucking in unmetered air. I did a search on that...
Jul 20, 2026
boatdude100
Still looking for helicoil size for the Top of outdrive dipstick tap. Its not the drain/fill plug at the bottom. Thank you
Jul 20, 2026
D
DeepCMark58A
posted the thread
in
Non-Boating Technical Topics
I ordered online a battery powered flow meter for my garden hose. I pump from the lake so now I can geek out on rate and total. Already...
Jul 20, 2026
WIMUSKY
reacted to
aspeck's post
in the thread
Trail camera issues fixed, now pics....
with
Like
Jul 20, 2026
boatdude100
Thank you, is the helicoil route generally the way people go or do the wise cough up the $ and replace the cap?
Jul 20, 2026
redneck joe
daily music fix
https://www.facebook.com/share/r/1LoYWySQ7S/
Jul 20, 2026
R
rbwhiz
reacted to
Lou C's post
in the thread
1996 Penta 5.0Fi and SX COBRA
with
Like
With fuel pumps, pressure, volume and vacuum are all important. pressure and volume are obvious, but vacuum will tell you if your anti...
Jul 20, 2026
redneck joe
Random
this always makes me smile https://www.facebook.com/share/v/195PdiiQ6D/
Jul 20, 2026
