replied to the thread
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
No roar, Honda's are quite ;)
Jul 21, 2026
C
chrisgt
suzuki prop vs turning point 4 blade prop; looking for advise
Yes, but it's only listed (as far as i can tell) for the df115A and up; for the larger size gear case. Maybe i'm missing something
Jul 21, 2026
acadian2022
1982 200hp high-performance "Franken-motor" hybrid build serial number 6033659 block casting has the J92W stamp
bade on AI :) Based on the photo, your engine has a 200 HP (2.4-Litre) powerhead. A previous owner likely swapped the block or the...
Jul 21, 2026
acadian2022
the 858-7790 is stamped bottom engine block below cylinder no 5 also added a gasket that was replace perhaps with the caliper indication...
Jul 21, 2026
Bob_VT
reacted to
DeepCMark58A's post
in the thread
Got my flow meter working today
with
Like
I also just ordered a filter to remove the stuff that clogs the sprinkler screens.
Jul 21, 2026
aspeck
Great loop speed record attempt
Bandit is trying to beat Youen’s solo Jon boat record.
Jul 21, 2026
redneck joe
did you get counter rotating?
Jul 21, 2026
redneck joe
all accurate
Jul 21, 2026
aspeck
It’s too quiet … where is the roar of the engines to prove all that power on the back end? 😂
Jul 21, 2026
dingbat
2000 Optimax 150s both overheating after spark plugs change. Need help
I One plug is platinum, the other is iridium. MGK says they are interchangeable with the only difference being the platinum is gapped...
Jul 21, 2026
Scott06
1997 5.7L thunderbolt ignition. Slow crank
The 090M 4.3 (M for metric) were used in early 2000s, yes unexplainable mix of metric threads on side motor mounts , starter bolts, and...
Jul 21, 2026
FLATHEAD
Sadly they are not setting any records this year. I saw a report ( if true) that the hull on the boat took some major damage and will...
Jul 21, 2026
T
tphoyt
Water Leaking Near Exhaust Plate - V4
Spray the bolts down with your favorite penetrating oil a couple days before your ready to remove them I you have the time.
Jul 21, 2026
FLATHEAD
reacted to
Stinnett21's post
in the thread
with
Like
Refresh my memory on this whole enterprise, is he trying to set the great loop speed record overall or the great loop Jon boat record?
Jul 21, 2026
dingbat
Really dry around here
We have no lakes. The rivers are killers (strong under tow) and you’re not the top of the food chain in other swimmable locations. The...
Jul 21, 2026
