F
findinghomer
replied to the thread
1997 5.7L thunderbolt ignition. Slow crank
Okay thanks for all that info. I think I've got it narrowed down to The Marine long block I posted above that already has the intake and...
Jul 21, 2026
C
crazy charlie
Constant drain of 1 of 2 batteries
One of the batteries for stbd engine and everything else, the other battery seems to be for port engine only. and I have a parallel...
Jul 21, 2026
R
1988 Johnson 150 ignition alarm question
Maybe the buzzer itself is defective.
Jul 21, 2026
Big Gee
reacted to
froggy1150's post
in the thread
Better solution for this "seat"
with
Like
1.If it is stout just bolt a seat on it with whatever size spacer you require. 2. Ifin it is flimsy..... stiffen it up... then step 1.
Jul 21, 2026
C
Crosbyman
black is usually ground this is a 16 year old post best to start a new post !!!
Jul 21, 2026
F
findinghomer
reacted to
nola mike's post
in the thread
with
Like
Wow, was looking over at michiganmotorz... things have become crazy expensive! 1. I personally wouldn't sweat getting a higher mileage...
Jul 21, 2026
J
JasonDom
2000 Optimax 150s both overheating after spark plugs change. Need help
I agree with the OP, stop chasing the plugs. Both numbers are correct for that engine. The timing of your plug change could be a...
Jul 21, 2026
acadian2022
1982 200hp high-performance "Franken-motor" hybrid build serial number 6033659 block casting has the J92W stamp
I can't thank you enough on your help my my.... I'm going to my last problem with this engine A arm advance timming WOT. when I...
Jul 21, 2026
C
Do the spark plugs need to be indexed?
Jul 21, 2026
acadian2022
Jul 21, 2026
P
Pmt133
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
I need a db meter to prove it. :ROFLMAO: I honestly couldn't tell you the last time I saw (heard) a Honda in the wild. That's a good...
Jul 21, 2026
P
Pmt133
1999 MerCruiser 4.3 Alpha 1 Gen 2 Ignition Type and Timing Question....
Damn spell check. Carb. I meant carb lol.
Jul 21, 2026
Dukedog
jus something ya might wanna check is tha bore's.. they should be "chrome plated".. if they are steel then its had replacement sleeves...
Jul 21, 2026
J
Jmunk
Exhaust bellow slipped off
I haven’t noticed a formula change in the adhesive in terms of its adhesion properties. Not to say they haven’t, I just haven’t been...
Jul 21, 2026
Dukedog
you have a 1st generation motor.. its a 2.4 175.. pre '83.. its basically a 200 block with tha vertical front half instead of tha...
Jul 21, 2026
