reacted to
matt167's post
in the thread
Engine misfires after rain storm
with
Like
New distributior cap, rotor, and wires with di electric grease in the connections.. see if it comes back. It probably won’t
Jul 21, 2026
Dukedog
replied to the thread
1982 200hp high-performance "Franken-motor" hybrid build serial number 6033659 block casting has the J92W stamp
motor mounted neutral safety switch hadn't come out yet.. was a few years later.. but there should be a neutral safety switch inside tha...
Jul 21, 2026
T
tphoyt
reacted to
racerone's post
in the thread
1968 Johnson 33HP - Model:RXE-16M Restoration Project
with
Like
These are an excellent motor.----Easy to repair / maintain.------Do a complete evaluation BEFORE spending beer tokens on parts.-----Do a...
Jul 21, 2026
F
findinghomer
reacted to
nola mike's post
in the thread
1997 5.7L thunderbolt ignition. Slow crank
with
Like
As mentioned you didn't need to mess with a cam. You need a marine fuel pump. Then yes just switch your stuff over. Wiring will be a...
Jul 21, 2026
acadian2022
yes I know what box your talking about some said it was my neutral switch most likely I got wrong info will check that box real good for...
Jul 21, 2026
K
kenny nunez
Does your engine cover allow water to land on the distributor? If so water is getting inside the distributor body through the flame...
Jul 21, 2026
E
elengineerio
posted the thread
1994 Evinrude 120 hp Looper .......cranks, fires, but dies after a second or two
in
Johnson & Evinrude Outboards
So the voltage regulator was replaced on the engine and all the wires went back as they should. Before replacing the VR the motor ran...
Jul 21, 2026
K
kenny nunez
1986 Baretta 3.0 mercruiser
Just remove the hose where it is connected to the manifold. If you do not have compressed air then insert the male end of the garden...
Jul 21, 2026
Berdink
reacted to
jimmbo's post
in the thread
Sputtering Johnson V4 90hp - 1994
with
Like
Best wishes on the trip, and happy boating
Jul 21, 2026
flyingscott
Water pump rebuild after 11 years and 600 hours
PEE stream means nothing. Only means that water got to that point. The only good pee streams are the ones plumbed in after the thermostat.
Jul 21, 2026
J
Jamz33
Thanks for the reply. Is there a video or anything to watch that shows me exactly how to isolate it?
Jul 21, 2026
G
gibbywmu2000
posted the thread
22' Sylvan Audio Upgrade - Subwoofer Backing Support Needed?
in
Electrical, Electronics, Audio and Trolling Motors
Hi All, Upgrading my 2016 Sylvan 22' Mirage 220 Audio System. I plan on mounting this Kicker MWF where the changing station door is...
Jul 21, 2026
G
Gallium
Thank you for the information. The cylinders were a bit hard to pull on the pull chord. I added a bit of oil from my other johnson boat...
Jul 21, 2026
E
elengineerio
120 hp Evinrude 4 cyl looper outboard - flywheel nut
Thanks for the suggestions......It really was a 1-7/16. I changed out the regulator but now there is a new problem which I will post...
Jul 21, 2026
tpenfield
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
Port engine is counter rotating prop. Starboard engine is standard rotation ( typical for twin OB installations) Honda V8 engine...
Jul 21, 2026
