B
brunolund
posted the thread
volvo 434a carb base gasket
in
Volvo Penta I/O & Inboard Gas Engines & Outdrives
hoping someone can help me here. I have a ‘94 volvo 434A and i need a carb base gasket. it has a holley 4175. the gasket that came with...
Jul 21, 2026
G
Gabel
reacted to
JB's post
in the thread
ATTENTION - Forum Rules - ATTENTION
with
Like
Moderators will edit or delete any posts in violation of the following, and may warn, issue infractions, suspend or permanently ban any...
Jul 21, 2026
jimmbo
replied to the thread
Sputtering Johnson V4 90hp - 1994
Best wishes on the trip, and happy boating
Jul 21, 2026
D
diegomzt
Jackplate yes or no
Alright! Thanks for your comments!
Jul 21, 2026
D
diegomzt
reacted to
Chris1956's post
in the thread
Jackplate yes or no
with
Like
I doubt you will gain any performance with a jackplate. Normally. jackplates are on really fast boats, to get the gearcase out of the...
Jul 21, 2026
D
diegomzt
reacted to
mr 88's post
in the thread
Jackplate yes or no
with
Like
Bigger question is , what prop is on it and whats your max rpm that you're seeing . Still a 18' boat with a 25 isnt going anywhere fast...
Jul 21, 2026
1986 Baretta 3.0 mercruiser
Ayuh,...... Isolate the block, 'n pressure test it with 'bout 15psi of air,... If the head, or block is cracked, you'll hear it...
Jul 21, 2026
stripped SX-A (3L VP) dipstick threads
or pull the cap and take it to your local radiator shop. they will weld it and re-tap it for about $30
Jul 21, 2026
reacted to
Bondo's post
in the thread
with
Like
Ayuh,...... No way I'd spend $600. for a new cap,..... Working on the bench, tap for the helicoil/ thread-sert, clean everything up...
Jul 21, 2026
1997 5.7L thunderbolt ignition. Slow crank
here is my typical starter and electric fuel pump wiring. verify the oil pressure switch connections, they are not standardized...
Jul 21, 2026
Jul 21, 2026
Dukedog
1982 200hp high-performance "Franken-motor" hybrid build serial number 6033659 block casting has the J92W stamp
tha box he's referin' to is mounted on top of tha air box stuff. will have a red, white and black best i remember.. they terminate on a...
Jul 21, 2026
dingbat
Constant drain of 1 of 2 batteries
A battery switch on the helm is weird. Never heard of or seen of such a thing on a Grady. I have a light at the helm that lets me know...
Jul 21, 2026
G
Gallium
reacted to
racerone's post
in the thread
1968 Johnson 33HP - Model:RXE-16M Restoration Project
with
Like
These are an excellent motor.----Easy to repair / maintain.------Do a complete evaluation BEFORE spending beer tokens on parts.-----Do a...
Jul 21, 2026
acadian2022
Good day. so I just came back boat in the water OUF when I discovered the bugging down at 2000 RPM my my I disconnected the trottle...
Jul 21, 2026
