redneck joe
replied to the thread
New Journey
if that 90 is running, and you are wanting to free up garage space, i might drive up for that.
Jul 21, 2026
M
Mc Tool
reacted to
flyingscott's post
in the thread
Water pump rebuild after 11 years and 600 hours
with
Like
PEE stream means nothing. Only means that water got to that point. The only good pee streams are the ones plumbed in after the thermostat.
Jul 21, 2026
eggs712
New Journey
Good looking rig, nice work.
Jul 21, 2026
M
Mc Tool
rant
6.5hp gzang zgong gong ping pong honda knock off . Im sick of having to chop up fish frames to fit them in a mincer ....sorta defeats...
Jul 21, 2026
eggs712
reacted to
MNhunter1's post
in the thread
New Journey
with
Like
Jul 21, 2026
C
ChazzL
posted the thread
Best Flushing Ear Muffs? Mine aren't working
in
Non-Repair Outboard Discussions
I spent hours tracking down the reason my Tell-Tale stream was not there. Water pump/impeller were fine, hoses were all clear, etc...
Jul 21, 2026
G
ganuski
posted the thread
HEI Distributor Conversion
in
OMC I/O & Inboard Engines & Outdrives
I installed a Sierra Marine Delco EST Conversion Kits 18-5514 on a 1985 OMC(GM) 5.7 Litre that had a Prestolite Points ignition. The...
Jul 21, 2026
acadian2022
1982 200hp high-performance "Franken-motor" hybrid build serial number 6033659 block casting has the J92W stamp
awesome BIG BIG thank you I will pass along all your helpful informations to the Shop owner. I welcome any feedback and will continue to...
Jul 21, 2026
redneck joe
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
side note, about time to plan for the pic to update your sig line - and how to concisely describe this thread in 10 words or less...
Jul 21, 2026
redneck joe
my fathers musings
What are your favorite books? The problem I have with trying to answer that question is that my favorite book is frequently the book I...
Jul 21, 2026
G
Gabel
posted the thread
Lakesport TX17 rear deck removal
in
Boat Restoration, Building, and Hull Repair
Trying to recarpet the rear deck and need some advice if it is screwed down or glued down. Any help would be appreciated.
Jul 21, 2026
Engine misfires after rain storm
you should have the crab cap..... those are a replace nearly every other year regardless type of thing. because the cap breaks down...
Jul 21, 2026
reacted to
matt167's post
in the thread
with
Like
New distributior cap, rotor, and wires with di electric grease in the connections.. see if it comes back. It probably won’t
Jul 21, 2026
Dukedog
motor mounted neutral safety switch hadn't come out yet.. was a few years later.. but there should be a neutral safety switch inside tha...
Jul 21, 2026
T
tphoyt
reacted to
racerone's post
in the thread
1968 Johnson 33HP - Model:RXE-16M Restoration Project
with
Like
These are an excellent motor.----Easy to repair / maintain.------Do a complete evaluation BEFORE spending beer tokens on parts.-----Do a...
Jul 21, 2026
