R
replied to the thread
1994 Evinrude 120 hp Looper .......cranks, fires, but dies after a second or two
I believe the big looper V-4 uses 140 FT-LBS for the flywheel nut.
Jul 21, 2026
C
Crosbyman
1968 33hp Johnson that Wont Die
6 years later ?
Jul 21, 2026
ezbtr
reacted to
Scott Danforth's post
in the thread
Mechanic tricks?
with
Like
one of the things I did today was use a 5# fist maul and a block of wood. the wood softens the blow so you dont leave marks, the 5#...
Jul 21, 2026
P
Pat_church25
posted the thread
1984 StarCraft SF14 transom bracing question
in
Boat Restoration, Building, and Hull Repair
Looking for some opinions on my idea for bracing my transom. I have a SF14 with a short transom that I converted to a tall transom. At...
Jul 21, 2026
E
elengineerio
Thanks for that info.
Jul 21, 2026
B
brucemustang
Stingray 20' Prop Issue
I’ can’t get my 2007 to plane out of water unless I put someone up in the bow and then it runs fine I went from a 21 pitch to a 17 it...
Jul 21, 2026
J
jlh3rd
Pontoon Questions: Jacking it up while on trailer? & What's this called?
I can get under my tandem pontoon bunk trailer and could put a 2x6 across a few ribs . They use these jack screw type support/jacks at...
Jul 21, 2026
B
brunolund
volvo 434a carb base gasket
thank you.
Jul 21, 2026
C
CFB
posted the thread
Pull start won't pull - antique engine
in
Johnson & Evinrude Outboards
Hello, I wasn't very successful searching for info and found this site. Pictures attached on what I have. I bought this 40 years ago...
Jul 21, 2026
You need an isolator gasket for a spread bore carb if your motor has a 4175
Jul 21, 2026
reacted to
Bondo's post
in the thread
1986 Baretta 3.0 mercruiser
with
Like
Ayuh,...... Isolate the block, 'n pressure test it with 'bout 15psi of air,... If the head, or block is cracked, you'll hear it...
Jul 21, 2026
reacted to
kenny nunez's post
in the thread
with
Like
Just remove the hose where it is connected to the manifold. If you do not have compressed air then insert the male end of the garden...
Jul 21, 2026
Best Flushing Ear Muffs? Mine aren't working
Measure your hose pressure and flow
Jul 21, 2026
Lakesport TX17 rear deck removal
Look in the carpet pile for screws
Jul 21, 2026
reacted to
MikeSchinlaub's post
in the thread
with
Like
Screwed down through the carpet most likely. The ply is either wrapped in carpet, then screwed to the frame, or screwed down first and...
Jul 21, 2026
