A
airshot
replied to the thread
I just got an older @
Gotta be videos out there that shows how everything goes together... There are videos of everything out there if you search hard enough.
Jul 21, 2026
A
airshot
rant
Get her to finish the detail while you Finnish the starter!!!....I know..wishfull thinking.....
Jul 21, 2026
A
airshot
New Journey
Thanks for the pics...brought back lots if fond memories. I had one if those back in the 80's. Great boat...ours had a 70 hp and would...
Jul 21, 2026
Stinnett21
reacted to
Lou C's post
in the thread
Always check the last thing you touched…..
with
Like
Ok last year had a bad season due to bad gas and found this out by running it on an outboard tank. Ok everything’s fine boat runs...
Jul 21, 2026
7
777funk
posted the thread
Force 50HP Carb Notes: 1985, a 1987, and a 91-92
in
Force & Chrysler Outboards
I figured that ALL Force 50HP Carbs interchanged through the years. But these two are quite a bit different. The throat is a bigger...
Jul 21, 2026
A
airshot
reacted to
nola mike's post
in the thread
Constant drain of 1 of 2 batteries
with
Like
So no connection between the batteries? What's a parallel switch? And stbd is the draining battery? Seems like an odd setup.
Jul 21, 2026
IslandExplorer
1974 Chieftain 25 "Adventurer" Restoration
Thanks! And I think you're right, it is pretty toasty in there without those big windows wide open and a good breeaze. I want to do tint...
Jul 21, 2026
S
saltchuckmatt
1994 Evinrude 120 hp Looper .......cranks, fires, but dies after a second or two
Make sure your tapers are perfectly clean and then after slightly lubricating the threads you want to use 105 ft lbs.
Jul 21, 2026
D
DeepCMark58A
reacted to
elengineerio's post
in the thread
with
Like
Okay solved it due to taking a picture of the wiring before I replaced the VR. I missed wiring in a couple of wires (orange and...
Jul 21, 2026
IslandExplorer
reacted to
Gibbles's post
in the thread
with
Like
It's coming out amazing. I see some tint in your near future. I used ceramic (3M) tint, keeps lots of the heat out of the cabin. Lots...
Jul 21, 2026
acadian2022
reacted to
Dukedog's post
in the thread
1982 200hp high-performance "Franken-motor" hybrid build serial number 6033659 block casting has the J92W stamp
with
Like
(y)
Jul 21, 2026
E
elengineerio
Jul 21, 2026
Dukedog
(y)
Jul 21, 2026
M
MikeSchinlaub
Lakesport TX17 rear deck removal
Screwed down through the carpet most likely. The ply is either wrapped in carpet, then screwed to the frame, or screwed down first and...
Jul 21, 2026
eggs712
22' Sylvan Audio Upgrade - Subwoofer Backing Support Needed?
I think the vibration/rattling of the sub will be the issue you'd have.
Jul 21, 2026
