flashback
replied to the thread
my fathers musings
I whole heartedly agree with him on the Patrick Obrien saga. I have most in paper back except for those that I loaned out over the years.
Jul 21, 2026
T
tank1949
Need advise on wax cleaner
I may just end up paying for all that elbow grease. Too old....
Jul 21, 2026
T
tank1949
reacted to
Scott Danforth's post
in the thread
with
Like
I use 800 grit, followed by Aquabuff 1000, followed by Aquabuff 2000, followed by 3M Finess-It. you have to get thru the oxidized layer...
Jul 21, 2026
flashback
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
I might be wrong,but I think Honda made the first 4 stroke outboards many years ago, I had a 7.5 bf75 on my old sailboat in 1976...
Jul 21, 2026
flashback
reacted to
Mc Tool's post
in the thread
rant
with
Like
6.5hp gzang zgong gong ping pong honda knock off . Im sick of having to chop up fish frames to fit them in a mincer ....sorta defeats...
Jul 21, 2026
T
tphoyt
Pull start won't pull - antique engine
Agree with above. You will likely find a tank there as well. Can you turn the flywheel by hand or is frozen up?
Jul 21, 2026
G
Gallium
1968 33hp Johnson that Wont Die
It's a very hard schematic to find outside of this forum. Six years worth of forum posts was how far I needed to go to find this.
Jul 21, 2026
R
It should turn without anything fancy that needs to be in the right position.----Visit----aomci-----For top notch help.
Jul 21, 2026
D
DeepCMark58A
rant
I put the boat in the water just enough to test the starter and the new temp sensor. I just the the replacement back cushion and I still...
Jul 21, 2026
D
DeepCMark58A
reacted to
airshot's post
in the thread
rant
with
Like
Get her to finish the detail while you Finnish the starter!!!....I know..wishfull thinking.....
Jul 21, 2026
nola mike
1997 5.7L thunderbolt ignition. Slow crank
I'll say I wish i didn't install a relay on mine and just wired it like OEM. Many connections have given me trouble, although my boat...
Jul 21, 2026
nola mike
Constant drain of 1 of 2 batteries
Can't be a regular battery switch, it would take too much high current wiring
Jul 21, 2026
L
lintmann
1999 MerCruiser 4.3 Alpha 1 Gen 2 Ignition Type and Timing Question....
Thanks Scott, that helps too. When I'm done I'll check my full advance to make sure I'm close to 24 BTDC and call it a day. Thanks.
Jul 21, 2026
L
lintmann
Oh ya, isn't spell check great lol, It always thinks it know more that you...
Jul 21, 2026
jimmbo
Pontoon Questions: Jacking it up while on trailer? & What's this called?
No Pressure Treated Lumber for the Bunks, as the Chemicals used to treat the Wood, will react with the Pontoons, which are likely Aluminium
Jul 21, 2026
