jimmbo
replied to the thread
1972 evinrude 50hp 2 stroke. Crank no start.
He is in Saskatchewan.
Jul 21, 2026
R
rbwhiz
1996 Penta 5.0Fi and SX COBRA
Well this has been what my next step is. That's with a clear line going straight into a gas can. But how's the dang thing running? Lol...
Jul 21, 2026
flashback
Pontoon Questions: Jacking it up while on trailer? & What's this called?
Still say, cut your new bunks to length, strap them down to the trailer and launch boat, spend a bit of time in the parking lot at...
Jul 21, 2026
SlipperyOar
1981 Springbok 18' Restoration/Renovation
I plan to get new tires for the trailer as these ones are beyond overdue for a replacement, extremely balded lol. I’m not quite sure why...
Jul 21, 2026
SlipperyOar
Two big things done the past few days… Got the few leaky rivets I had sealed up and watertight using Gluv-it. I used a heat gun to...
Jul 21, 2026
R
Pull start won't pull - antique engine
I think you remove the flywheel by loosening the nut.----No puller required.-----And nothing will jump at you either.
Jul 21, 2026
flashback
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
Never heard of them, how were they, probably a bit troublesome I'd guess.
Jul 21, 2026
flashback
reacted to
racerone's post
in the thread
with
Like
I believe Lauson made a 4 stroke in the late 1940's.
Jul 21, 2026
C
CFB
Thank you for the resource. Correct, I cannot spin the flywheel by hand nor does it budge with a cord. I wasn't sure if I could just...
Jul 21, 2026
R
The ignition does not use 12 volts to make the spark.-----The flywheel must spin fast to energize the ignition system.----Your location?
Jul 21, 2026
Ifishmuskie2
1984 StarCraft SF14 transom bracing question
I like what you have done so far. I would like a panel (either wood or aluminum ) on the outside of the stern to sandwich everything...
Jul 21, 2026
P
Pmt133
reacted to
Scott Danforth's post
in the thread
Need advise on wax cleaner
with
Like
I use 800 grit, followed by Aquabuff 1000, followed by Aquabuff 2000, followed by 3M Finess-It. you have to get thru the oxidized layer...
Jul 21, 2026
I
icatchfish
Appreciate it. They do not have one in stock. And considering the cost of one is about the cost of what I paid for my boat I'm not eager...
Jul 21, 2026
R
Jul 21, 2026
P
Pmt133
reacted to
flashback's post
in the thread
with
Like
I might be wrong,but I think Honda made the first 4 stroke outboards many years ago, I had a 7.5 bf75 on my old sailboat in 1976...
Jul 21, 2026
