nola mike
reacted to
froggy1150's post
in the thread
Better solution for this "seat"
with
Like
1.If it is stout just bolt a seat on it with whatever size spacer you require. 2. Ifin it is flimsy..... stiffen it up... then step 1.
Jul 22, 2026
nola mike
replied to the thread
1997 5.7L thunderbolt ignition. Slow crank
Personally think that if you're going used (rolling the dice) you'd be better off with a truck engine. Even abused, the block has an...
Jul 22, 2026
ranger335
1981 Johnson 90 HP overheating, but not all the time
Heat sensors and gaskets on order. Wish me luck!
Jul 22, 2026
T
tphoyt
reacted to
aspeck's post
in the thread
Nobody fishing?
with
Like
20 days till my Alaska fishing adventure ... getting excited!
Jul 22, 2026
1986 Baretta 3.0 mercruiser
it should hold 15 psi with the valve shut off for perpetuity. if it leaks air, you have a leak.
Jul 22, 2026
No Reverse or Neutral....just Forward VP
First, follow the manual on adjusting the linkage at the outdrive. that involves removing the cover on the back of the drive. (item 72)...
Jul 22, 2026
JonBoat55
reacted to
FLATHEAD's post
in the thread
Nobody fishing?
with
Like
So I rigged up a phone holder in my boat to try to get better quality pictures. First morning out and I managed a smallmouth worth a...
Jul 22, 2026
FLATHEAD
reacted to
aspeck's post
in the thread
Nobody fishing?
with
Like
Jul 22, 2026
FLATHEAD
reacted to
BWR1953's post
in the thread
Nobody fishing?
with
Like
My wife and I headed over to the fishin' hole this evening. We haven't been fishing since March. We were definitely overdue. I...
Jul 22, 2026
J
Jamz33
Thanks. Totally missed that part.
Jul 22, 2026
D
DeepCMark58A
reacted to
aspeck's post
in the thread
Nobody fishing?
with
Like
Jul 22, 2026
Not real familiar with VP cables, but @Lou C , @kenny nunez , or @Scott Danforth should be
Jul 22, 2026
N
Nordin
Force 2 cylinder throttle cable adustments
metalchewy, the dynamic setting has to be under load. If you will adjust the timing in a barrel you have to have a test propeller. Hard...
Jul 22, 2026
Horigan
reacted to
Scott Danforth's post
in the thread
stripped SX-A (3L VP) dipstick threads
with
Like
or pull the cap and take it to your local radiator shop. they will weld it and re-tap it for about $30
Jul 22, 2026
redneck joe
reacted to
aspeck's post
in the thread
Nobody fishing?
with
Like
Jul 22, 2026
