replied to the thread
Lost my mooring
thats great. last I remember, you were splitting the sail boat cap from the hull. did that ever get finished?
Jul 22, 2026
jimmbo
Force 2 cylinder throttle cable adustments
Hanging over the transom above a Flywheel spinning over 4500rpm, is not my idea of a good time, especially if the Water, isn't like Glass
Jul 22, 2026
E
Eddie1920
Help identifying v4 johnson
can i measure the bore of the carb throats to determine which carbs they should be 115, 140 etc
Jul 22, 2026
R
How does my 1997 Force 75hp sound
Sounds perfect.-----Do final mixture adjustment with boat in the water.----In gear and warmed up.
Jul 22, 2026
tpenfield
Lost my mooring
Speaking of moorings . . . I just got notice from the Harbor Master that a mooring is available for my sailboat :love: . Well you...
Jul 22, 2026
N
Nordin
As I mention earlier you set the timing at WOT (Wide Open Throttle). That is why I do not set it dynamic, you have to be at least two in...
Jul 22, 2026
R
rbwhiz
1996 Penta 5.0Fi and SX COBRA
Yes.... It ran pretty much the same. Low pressure pump has been ordered. While the gas in the filter looked like crap, but the gas I...
Jul 22, 2026
metalchewy
reacted to
aspeck's post
in the thread
Nobody fishing?
with
Like
20 days till my Alaska fishing adventure ... getting excited!
Jul 22, 2026
LunaStarcraftJupiter
posted the thread
in
Force & Chrysler Outboards
I just removed and cleaned the carb. Replaced the inlet needle. and set idle screw to what it was at before taking it apart. I also...
Jul 22, 2026
metalchewy
Ok. Thanks for the clarification. Will put my spare timing light into the dry bag. Going out Saturday morning. When you say under...
Jul 22, 2026
metalchewy
reacted to
Nordin's post
in the thread
with
Like
metalchewy, the dynamic setting has to be under load. If you will adjust the timing in a barrel you have to have a test propeller. Hard...
Jul 22, 2026
Lou C
No Reverse or Neutral....just Forward VP
With that plastic cover off, Have someone watch the shifter bell crank on the outdrive while you work the control t see if it is moving...
Jul 22, 2026
Better solution for this "seat"
thats just a pedestal. you need to mount a seat to it
Jul 22, 2026
C
crazy charlie
Constant drain of 1 of 2 batteries
Got the boat with that setup over 20 years ago and never thought twice about it. Never an issue. Parrelel switch is a spring loaded...
Jul 22, 2026
dingbat
My last boat had a similar setup except it had a door and mounted a pedestal seat to the top
Jul 22, 2026
