replied to the thread
Cobalt 226 vs 220 or something else..
Anything Cobalt should be a good ride, there heavy The B3 is real nice for docking, it bites real good. If your going to keep it in...
Monday at 5:48 AM
AQ130 Wiring Diagram Drawn
I like it
Monday at 5:42 AM
M
MikeSchinlaub
reacted to
Seasons Recreational's post
in the thread
Aluminum transom has had heat distortion
with
Like
Here’s a later photo after he took it out of the booth
Monday at 5:42 AM
M
MikeSchinlaub
reacted to
in the thread
with
Like
Have an update on the solution I elected…. After all the welding was done. The back and the inside of the transom was looking pretty...
Monday at 5:42 AM
reacted to
MikeSchinlaub's post
in the thread
Boats from work.
with
Like
I forgot to post pics of the finished waverunner.
Monday at 5:41 AM
M
MikeSchinlaub
Boats from work.
Monday at 5:40 AM
you know the schematics are in the VP manual
Monday at 5:06 AM
reacted to
Scott06's post
in the thread
4.3 Mercrusier carb questions
with
Like
Get yourself an ultrasonic cleaner from harbor freight or similar. My carb rebuilding batting average went way up when I started using...
Monday at 5:05 AM
reacted to
jimmbo's post
in the thread
with
Like
I have always used Lacquer Thinner for cleaning carbs, taking care not to put any plastic parts in it, Parts come out of it clean, not...
Monday at 5:05 AM
redneck joe
cooking
wife and i did a taste test between hellmans, dukes and blue plate
Monday at 5:00 AM
redneck joe
cooking
omg just might have peed myself a bit....
Monday at 4:59 AM
Grub54891
reacted to
in the thread
with
Like
Monday at 4:51 AM
Grub54891
reacted to
in the thread
with
Like
Monday at 4:51 AM
C
1984 Mercury Black Max 150 hard start and wont idle.
You might check to see if the choke is working, however, it is usually only needed when the motor is first started that day. On my '93...
Monday at 4:44 AM
C
Mercury 850 85hp. Good engine or stay away?
I am not sure I understand your post. Generally, if the rectifier is connected to the 2 stator wires, but not ground or +12VDC, it will...
Monday at 4:41 AM
