C
replied to the thread
Need HELP identifying motor first
Gee, what does the manual specify for initial low speed setting? For my '98 Johnny 150HPV6 the initial setting is 5 turns open. The...
Wednesday at 5:10 AM
tpenfield
reacted to
redneck joe's post
in the thread
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
with
Like
a step stool in a bilge...
Wednesday at 4:38 AM
R
Are you pushing the key in and holding it in while cranking it over?----Simpler to do and the same as spraying starter fluid in...
Wednesday at 3:50 AM
reacted to
Leedanger's post
in the thread
Livorsi Wire harness diagram
with
Like
Figured it out and it was indeed the notorious failed diode. I made a video describing the repair in surface level detail just incase it...
Wednesday at 3:46 AM
reacted to
Fun Times's post
in the thread
Engine is gas lighting me
with
Like
Theory/s... Looking at the design of your oil dipstick to oil pan configuration, one thought could be how was the condition of the old...
Wednesday at 3:37 AM
R
84' Johnson 75hp shifter adjust
I would install a seal kit on this 50 year old motor.---In neutral the lever under the carburetor should be vertical.----And 21-23/32 in...
Wednesday at 3:36 AM
R
Shift Lever Pin Installation on 1986 Johnson 150 Crossflow J150TXCDC
Removing the lower carburetor may make it easier for you.-----Have done this procedure many times without removing the...
Wednesday at 3:32 AM
redneck joe
Random
and i grew up reading Bloom County and this..
Wednesday at 2:42 AM
redneck joe
Artificial Intelligence
Wednesday at 2:40 AM
redneck joe
Random
ok i post a lot of stuff here on this thread but yall cannot argue with the fact this is 100% the most accurate thing i've ever posted...
Wednesday at 2:28 AM
redneck joe
Random
Sometimes the things that may or may not be true are the things a man needs to believe in the most
Wednesday at 2:17 AM
redneck joe
Random
Jewpacabra is in microsoft spell check...
Wednesday at 12:47 AM
K
KM7
posted the thread
Overheating Possibly Caused by Restricted Thermostat Housing Port
in
OMC I/O & Inboard Engines & Outdrives
1991 Four Winns 200 with 5.8 L Ford V8 and OMC OD. I was cruising the harbor on Sunday with friends and noticed overheating at the port...
Wednesday at 12:29 AM
Fun Times
Wednesday at 12:22 AM
redneck joe
Random
Tuesday at 11:51 PM
