T
tphoyt
replied to the thread
New to Wake Sports – Looking for Beginner Advice
I remember using a pice of plywood shaped like a surfboard. It worked pretty good until you leaned to far forward then it turned into a...
Wednesday at 6:04 AM
redneck joe
Random
the story is.... https://www.facebook.com/share/v/1Yh1brdthU/
Wednesday at 6:02 AM
C
Mercruiser 5.0 replacement
You could put the blue dye on the head mating surface and a piece of sandpaper on a piece of plate glass and rub the head around to see...
Wednesday at 5:56 AM
D
Dalejam
Need HELP identifying motor first
If the flywheel key was sheered wouldn’t it be out of time for the magnets are telling the aystem When to fire properly ? As for...
Wednesday at 5:55 AM
redneck joe
Random
https://www.facebook.com/share/r/1F7UtKCvgY/
Wednesday at 5:50 AM
C
Mercury 850 85hp. Good engine or stay away?
Gee, that should work. You might test the diode with an ohmmeter, to make sure it is still good. If not, Amazon likely has a 15 to 25A...
Wednesday at 5:42 AM
reacted to
redneck joe's post
in the thread
Artificial Intelligence
with
Haha
Wednesday at 5:35 AM
Cup420
Help...50hp 4stroke 2003
Question... How am I supposed to heat the engine up and to pull the spark plugs? Doesn't that make the spark plugs easier to break? I'm...
Wednesday at 5:31 AM
Cup420
reacted to
boscoe99's post
in the thread
with
Like
When doing the compression test, was the motor fully warmed up, throttle wide open, battery fully charged and the gauge known to be...
Wednesday at 5:29 AM
Grub54891
reacted to
roscoe's post
in the thread
with
Like
Wednesday at 5:25 AM
Grub54891
We used the neighbors round plywood disk! The neighbor kid would take a wooden chair and sit on it while doing that! I always tipped...
Grub54891
reacted to
roscoe's post
in the thread
with
Like
Pretty much what we did in the 1960's, with a 14' boat and a 25 hp motor. https://www.facebook.com/reel/1512996310486124
Wednesday at 5:24 AM
reacted to
cjstimpson's post
in the thread
with
Like
To not leave this story open ended, I learned both head gaskets are blown and an exhaust valve was stuck open. Next, I'd like to know...
Wednesday at 5:19 AM
1997 5.7L thunderbolt ignition. Slow crank
I've never pulled a motor by removing the screws holding the mount, always removed the top nuts and rear bolts. It might be easier to do...
Wednesday at 5:15 AM
C
Fourwinns doors shut
I ended up with a '98 SeaSwirl 2100 DC with a 150HP Johnny. Sorry, no picture
Wednesday at 5:12 AM
