R
replied to the thread
May Day help
Test run with a portable tank and hose.
Wednesday at 7:19 AM
R
Need HELP identifying motor first
Facr---If flywheel key is sheared the timing light does NOT show that.
Wednesday at 7:18 AM
B
Built For Speed
posted the thread
May Day help
in
Mercury & Mariner Outboards
1987 Mercury Black Max XR2 150 HP (Serial 0A969708) Engine starts immediately and runs great. I replaced the water pump, fuel filter...
Wednesday at 7:15 AM
Cup420
Help...50hp 4stroke 2003
Truthfully, I don't think that compression is my problem. That's just one of the first things you check. So that's my idea behind it. I...
Wednesday at 7:07 AM
A
airshot
Building a fishing boat.
No headlights while running, can be used as an on off light for docking or a quick flash on to see objects floating while going slow...
Wednesday at 7:01 AM
C
Mercruiser 5.0 replacement
So why did the valve stick open? Valve timing jump? Overheat? That needs to be figured out and rectified.
Wednesday at 7:00 AM
A
airshot
reacted to
Scott Danforth's post
in the thread
with
Like
Headlights are not legal
Wednesday at 6:58 AM
C
cjstimpson
reacted to
Chris1956's post
in the thread
with
Like
You could put the blue dye on the head mating surface and a piece of sandpaper on a piece of plate glass and rub the head around to see...
Wednesday at 6:57 AM
C
cjstimpson
Yes, the valve is bent. There's also signs it has been hit by the piston.
sloopy
Boats from work.
I’m curious about that little 35 year old pwc from earlier. Is it common for people to restore them? How much are they paying (roughly)...
Wednesday at 6:54 AM
reacted to
Chris1956's post
in the thread
with
Like
Wednesday at 6:41 AM
Cup420
Doing a compression test and something isn't right. When I have the throttle closed, or off just on the one cylinder, i'm testing right...
Wednesday at 6:33 AM
D
DeepCMark58A
2026 NFL/CFB News and Nonsense
SKLOL
Wednesday at 6:30 AM
aspeck
reacted to
redneck joe's post
in the thread
Random
with
Like
Wednesday at 6:18 AM
T
tphoyt
Random
Way to much fun filming that. And I guess it’s true Evinrudes are bullet proof.
Wednesday at 6:10 AM
