replied to the thread
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
Wednesday at 8:26 AM
B
brunolund
Lund tyee I/O transom removal
if i remember correctly, it wasn’t tight to the sides or bottom. i think there was about a 1” gap all the way around. i was thinking id...
Wednesday at 8:20 AM
Scott06
Mercruiser 5.0 replacement
Look for rust on the valves that might indicate water coming in through the exhaust. You need a long machinist rule and feeler gauge to...
Wednesday at 8:14 AM
Scott06
1997 5.7L thunderbolt ignition. Slow crank
I dont think it matters dealers choice. On my set up the lags were easier to get to with a wobble extension due to a side panel that...
Wednesday at 8:12 AM
Scott06
Engine misfires after rain storm
Not sure on the stator driven set up but this 1974 Evinrude is a coil eater. I went through everything but the coils as I saw spark on...
Wednesday at 8:11 AM
M
MikeSchinlaub
Boats from work.
I would say it's not very common. I've only seen a few of these older styles, and one other that was totally resprayed, yellow and...
Wednesday at 8:09 AM
Lou C
Your cylinders look OK, I'd carefully clean off the old head gaskets, clean up the block deck and measure it. If both sides are good...
Wednesday at 8:08 AM
M
MikeSchinlaub
Ok, I get it now. I think I've done one like that a long time ago. The problem withthe rivets is you would have to have them back in...
Wednesday at 8:07 AM
Lou C
if you look close you can see I have a stuck valve like yours, prob due to water in the cyls from blown head gasket.
Wednesday at 8:04 AM
Lou C
I had the same problem on my old 4.3, but it ran fine for 2.5 seasons before getting a bit of water in the front 2 cyls. I checked the...
Wednesday at 8:03 AM
B
Built For Speed
May Day help
Thank you good idea
Wednesday at 7:53 AM
Big Gee
reacted to
racerone's post
in the thread
1992 OMC 3.0 Cracked Block
with
Like
If it " runs " many sellers like you to think that there is nothing wrong with it.
Wednesday at 7:52 AM
Lou C
Looks great, I'm still getting used to yellow "ground" wires lol.
B
Built For Speed
reacted to
racerone's post
in the thread
May Day help
with
Like
Test run with a portable tank and hose.
Wednesday at 7:50 AM
R
Help...50hp 4stroke 2003
Well---200 PSI for a 4 stroke ( throttle open ) sounds correct !
Wednesday at 7:41 AM
