Scott06
replied to the thread
Mercruiser 5.0 replacement
the new long block I bought in 2016 is just about x2 now. Hard part is if there is a decent machine shop you will be waiting for them...
Wednesday at 9:28 AM
reacted to
MikeSchinlaub's post
in the thread
Lund tyee I/O transom removal
with
Like
Ok, I get it now. I think I've done one like that a long time ago. The problem withthe rivets is you would have to have them back in...
Wednesday at 9:20 AM
D
DeepCMark58A
2026 NFL/CFB News and Nonsense
Do you think KOC might be on the hot seat if the season does not go well? 4 seasons still no post season win?
Wednesday at 9:12 AM
C
Have you checked the exhaust manifolds for water leaks into the exhaust passages? Also check the manifold to riser joint for leaks past...
Wednesday at 9:04 AM
C
May Day help
Check spark immediately after it dies.
Wednesday at 9:01 AM
WIMUSKY
reacted to
Chris1956's post
in the thread
Fourwinns doors shut
with
Like
I ended up with a '98 SeaSwirl 2100 DC with a 150HP Johnny. Sorry, no picture
Wednesday at 8:59 AM
WIMUSKY
Wednesday at 8:58 AM
C
Tachometer/Regulator Question
That looks to be the water cooled voltage regulator. I bought one from CDI or Sierra, and it rusted out in a couple of years use in...
C
cleve
Got some time this morning to test battery. It was 11.77 at rest and 11.72 with engine running at high idle. Assume the rectifier is...
Wednesday at 8:55 AM
Lou C
I got a bargain on my 4.3 V6 remans….$275 each BUT that was back in 2017! I used compressed air, solvent, gun brushes and thread...
Wednesday at 8:52 AM
IslandExplorer
reacted to
66Holiday924's post
in the thread
1978 Islander 22 I/O
with
Like
yeah, they cut the plexiglass a little small in one area. Overall, I don't really care for how it's all fitting together, but looking at...
Wednesday at 8:33 AM
Cup420
posted the thread
Ohm specs
in
Yamaha & Suzuki Outboards
2003 Yamaha 50hp 4stroke... Looking for the ohm and k-ohm specs. Struggling to find this information and need to test.
Wednesday at 8:29 AM
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
Wednesday at 8:26 AM
B
brunolund
if i remember correctly, it wasn’t tight to the sides or bottom. i think there was about a 1” gap all the way around. i was thinking id...
Wednesday at 8:20 AM
Scott06
Look for rust on the valves that might indicate water coming in through the exhaust. You need a long machinist rule and feeler gauge to...
Wednesday at 8:14 AM
